Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
How to find a good hooker?
Old 02-29-2012, 12:33 PM
Prorac1's Avatar
Default How to find a good hooker?
Now that I have your attention, lol. What are the Carburated guys using to lift thier engines into the cars? I could use the carb mounting flange style, or ive always seen the valley cover plate style also. Im thinking the carb style would be more versitile for other vehicles I work on, but wondering what everyone else is doing. Thanks, Eric L
Old 02-29-2012, 12:47 PM
3pedals's Avatar
lol I used a fiber 4ft sling choked under the plenum of the manifold front to back. I think it worked great. carb flange lifting bracket would be what I used otherwise
Old 02-29-2012, 02:00 PM
Prorac1's Avatar
Ive given thought about the carb flange ones before, but the idea of lifting an entire motor up with 4 3/8 bolts threaded into aluminum makes me nervous. I like the strap/sling idea though. Eric L
Old 02-29-2012, 02:56 PM
Pop N Wood's Avatar
I welded up some flat steel in T's with a chain slot to bolt to the front of one and the back of the other head. That allowed me to use a leveler.
Really the carb manifold bracket is more than strong enough. I have seen guys using nothing more than an exhaust manifold bolt on either side of the motor.
Old 02-29-2012, 03:27 PM
Doug G's Avatar
I just can't bring myself to use the carb flange one But that's me.
I've always used the exhaust bolt holes or front and rear accessory bolt holes on the heads (cross corner).
May have to try that strap idea though
Old 02-29-2012, 09:00 PM
Spoolin_Notch's Avatar
I lifted out a BBC today using just the carb plate.. worked for me, and I've done it a 100+ times, Not exactly sure the weight is one a lsx but Im sure the BBC is heavier.
Old 03-01-2012, 07:36 AM
Prorac1's Avatar
Thanks for all the info guys. Eric L
Old 03-01-2012, 09:06 AM
MikeFSKSpeed's Avatar
Ive used the carb plate 1000 times with no issues.
IF you still need I have plenty in stock. $16 shipped
Old 03-01-2012, 09:33 AM
Prorac1's Avatar
Thanks Mike. What brand and part number is it? Thanks Eric L
Old 03-01-2012, 09:52 AM
newschool72's Avatar
I bought one of those four corner deals with the leveling crank. I will not put another motor in without it, especially if the trannie is attached. Gives complete control of motor/trannie angle going in. Thing made ME look like i knew what i was doing!
Oh, and I used the acc holes in the heads on all four corners.
Old 03-01-2012, 09:59 AM
Prorac1's Avatar
The problem I run into with my perticular setup is that the motor is VERY close to the firewall. SO bolting a chain or strap to the back of either head is out. Thats why im leaning towards the carb mounting flange idea. And with a mid plate mounted to the chassis, tipping and aligning is not really a problem. Although, the hillbilly in me really, REALLY likes Barrets sling idea, lol. No really, Ive never thought about it before, thats kinda slick, lol. Eric L
Old 03-01-2012, 10:18 AM
3pedals's Avatar
I AM Kinda a hillbilly, lol
Old 03-01-2012, 10:32 AM
Prorac1's Avatar
Im from michigan.........................I can dig it, lol. Yoopers UNITE, lol. Eric L
Old 03-01-2012, 10:38 AM
http://www.skspeed.com/ProductDetail...oductID=S71903
Through the website it charges shipping but If you were interested let me know for that $16 shipped. Doesn't work on dominator flanges!
Old 03-01-2012, 01:08 PM
The sling around the intake definatly works. That is how I got the motor off the truck. Takes some strong finger action to loosen the cinch on the strap when you take it off though. well at least the way mine was wrapped up.
Old 03-01-2012, 03:23 PM
Prorac1's Avatar
Hey Mike, can you get a brand called performance tool. Part number w41034? It has the mounting flanges for dominator and 4150/4160. For me and my buds, we need both. Thanks, Eric L
Old 03-01-2012, 06:52 PM
In-Zane Moderator
ZONES89RS's Avatar
Been using carb mounted plates since I started yanking and installing carbed engines, never had a hiccup, even with a transmission attached, so if that is not good enough, then the valley cover design is the only other option I assume.
Old 03-01-2012, 06:55 PM
ilovechevy1's Avatar
on the corner
Old 03-01-2012, 07:06 PM
Prorac1's Avatar
Lol, I was waiting for someone to come up with that one, lol. Eric L
Old 03-01-2012, 10:21 PM
toxic99's Avatar
I do it same way with a lvler too
