Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
MSD 6010 wont rev passed 2200rpm
Old 06-03-2012, 01:27 PM
lsx74camaro's Avatar
Default MSD 6010 wont rev passed 2200rpm
Just got my turbo lm7 fired up and it runs great at idle. But once i rev it it starts misfire and limits its its rpm to around 2200 but the limiter isnt hooked up. I pulled each coil they are working changed plugs, changed carb, fuel pressures good, hooked up laptop everythings looks fine.
Old 06-03-2012, 02:29 PM
Video uploaded,
Old 06-03-2012, 04:22 PM
89gmcs15's Avatar
that really sounds like a limiter of some sort. going thru the basics, the high limiter isnt set to 2200 in the msd box is it? also is the low limiter (2 step) set to anything and the switch is on or somehow activating? plug your laptop in and see what the timing and stuff is doing while its doing it. thats a nice feature for this nifty little box i thought. im running a 6010 aswell and this really sounds like a limiter and not a missfire more like something electronically controlled...
Old 06-03-2012, 04:50 PM
I tryed running on one of the chips then i removed the chip,
adjusted with the laptop , same result.
Old 06-03-2012, 05:23 PM
Pop N Wood's Avatar
How do you know it is the ignition and not a lack of fuel
Old 06-03-2012, 05:27 PM
Used tryed two carbs my 650 then my 850 of my big block exact same result.
Old 06-03-2012, 05:29 PM
And the wideband is showing around 12.5:1 afr
Old 06-03-2012, 05:41 PM
In-Zane Moderator
ZONES89RS's Avatar
Where are the limiters on the box set?
Old 06-03-2012, 05:46 PM
Low is set at 3k and high is 6.5k, I think the 5.3 might be trying to save it self, cause im starting of with 13 lbs of boost with the 88mm and 100 shot to spool it. Its hard to tune when it wont go above 2k.
Old 06-03-2012, 05:53 PM
In-Zane Moderator
ZONES89RS's Avatar
Hard? You mean impossible. Os boost coming in for some reason that soon? I would imagine not with that size hair dryer. Make sure the low end limiter is not activated, watch the lap top, it should tell you, at 3000, the tach is not going to keep up some times and may only show 2200 or so.
Old 06-03-2012, 06:25 PM
bad67ls's Avatar
do you maybe have the 2 step wire run to constant 12 volts?
Old 06-03-2012, 09:15 PM
Low rev limiter wire isnt hooked up, i looked at the tach on the computer screen 2200 rpm when it misses every time ,checked all the limiters normal and i saved everything to the controller, i contacted MSD hope they might be able to figure it out. I never seem to have any luck with electronics, i thought the valves might have been sticking open cause i put .025 longer pushrods for the ls6 cam. But it idles perfect and like i said 2200 rpm exact everytime and wont rev. passed that.
Old 06-04-2012, 12:20 AM
massen1981's Avatar
where do you have your msd box wired to. sounds like you have som volt drop over to msd power suplye.
Old 06-04-2012, 01:02 AM
Hmm never thought of that, voltage is coming from the old coil supply, when i used hei on my old engine i used a relay cause the coil supply was getting to hot i didnt think the controller took much amperage, i will have to try that.
Old 06-04-2012, 01:50 AM
In-Zane Moderator
ZONES89RS's Avatar
Needs a constant minimum 12 v.
Old 06-04-2012, 02:07 AM
I will find another power tonight, but if there is somthing wrong with the controller i hope MSD warranty is good, cause i had the controller a year on the 28th of this month, I thought i was screwed cause i was reading a revised version of the instructions and the warranty disclaimer is about 3 sentences longer than the version i got with my controller and it states "This warranty is void for any products purchased through auction websites" I bought it new ,buy now, off ebay from a 100% feedback online store like i buy most of my stuff for security purposes. I went on msd site and went on their warranty page and it didnt say anything about auction websites.
Old 06-04-2012, 07:06 AM
In-Zane Moderator
ZONES89RS's Avatar
Call them, tell them it has been sitting and you just installed it and would like them to check it out.
Old 06-04-2012, 03:03 PM
westTEX26's Avatar
I don't think this has anything to do with it but you are running a Blow-Thru carb right?
What turbo you got??
Old 06-04-2012, 05:00 PM
Yes its blow thru ,running a 850 with annular boosters and BRPV ,aeromotive a1000 eliminator pump and a boost ref. regulator. Turbo is a majestic 88mm T6 .96 a/r comp., 1.00 turbine, home built log style manifolds 1.75" into 3". 2.5" into 4" hotside, 4" down pipe, 3" cold side, a2a intercooler, meth injection, nitrous. After i first started up it did the same as the video ,then i put a 650 and took the video, exact same result.
Old 06-04-2012, 07:49 PM
westTEX26's Avatar
Well that sucks, it defiantly sounds like the limiters hitting. Maybe try it with the carb-hat off and see what happens.
Quick Reply: MSD 6010 wont rev passed 2200rpm
