Mechanical oil/water gauge
You take the sensors off the original motor and adapt them to your LS. You can get a T for the oil pressure sender. For water temp you will need to adapt the sender, since it is mechanical most likely by T ing something into a radiator line. The stock temp sender is too small for much of anything else. Another option is the brass block heater plug, you can easily tap that for 1/2 NPT
I drilled and tapped my head for the mechanical sensor. I also broke the plastic off the oil sensor behind the valley cover and drilled and tapped that for 1/8 npt. No issues either. No adapter fittings to break
oil pressure
I 'gutted' the factory oil sender at the back of the block and there was a little hole. I pressed the tubing for the oil gauge in - was very tight. I put a glob of JB Weld just in case. That was 2 years ago, works perfectly.
Drill existing temp sender hole in the head to 37/64" (verify that pretty sure that's right) and tap the hole with 3/8 NPT.
Yea I'll bro ably just don't he oil sensor by the oil filter and water temp in water hose see how all this goes! Thanks for all the help if that don't work I'll try some if these out
The one on the left is the stock brass heater plug drilled and tapped 1/2 npt. The second is a 1/2 to 3/8 npt reducer. The last one I got from either a sunpro or equus adapter kit
http://www.autozone.com/autozone/acc...ier=39184_0_0_
http://www.summitracing.com/parts/su...FWUOOgodbDEApQ
http://www.ebay.com/itm/Oil-Pressure-Sender-Adapter-Water-Temp-Adapter-combo-LS1-LS2-LSx-/181318717522?pt=Motors_Car_Truck_Parts_Accessories&hash=item2a37701052&vxp=mtrhttp://www.ebay.com/itm/LS1-LS2-LS6-LQ4-LQ9-Mechanical-Oil-Pressure-Gauge-Adapter-Fitting-BLOCK-5-8-18-/380829688904?pt=Motors_Car_Truck_Parts_Accessories&hash=item58ab37e448&vxp=mtr
