Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Fuel Pumps
Old 02-21-2014, 09:27 PM
LP_chito's Avatar
Post Fuel Pumps
What fuel pump set ups are you guys using I got a 5.3 build I'm gunna go carb wit the mad 6010 on a fox body. Probably go nitrous route. Thanks guys.
Old 02-21-2014, 09:38 PM
In-Zane Moderator
ZONES89RS's Avatar
A Holley blue will
Keep up on motor.
I always suggest a aeromotive street and strip, either the self regulated version that doesn't need a return or the other that needs a bypass and return.
And I always suggest running a dedicated fuel system separate for the nitrous and I use a Holley blue for that.
Old 02-21-2014, 09:44 PM
LP_chito's Avatar
Thanks man . Around wat psi is good ? Do you have any part numbers on the aeromotive pump
Old 02-21-2014, 10:11 PM
In-Zane Moderator
ZONES89RS's Avatar
6.5 is fine.
http://www.jegs.com/webapp/wcs/store...=&pgGrp=search
And the built in regulated version:
In-Zane Moderator
ZONES89RS's Avatar
Mike at SK speed can give you the best deal, hit him up for sure for all your carbed LS needs, he takes care of us!
Old 02-22-2014, 09:09 PM
LP_chito's Avatar
Thanks a lot man really appreciate it !!
Old 02-22-2014, 09:14 PM
EastTnZ28's Avatar
Holley Blue if your on the cheap. Noisy but cheap. Ive got baffled headers for exhaust so I cant hear anything but sweetness.
Old 02-22-2014, 11:36 PM
LS1BADZ's Avatar
I've been trying to decide on a setup as well, don't know if you can run a 60+psi pump to a regulator then a return. I'd prefer to run a regulator and return line.
Quick Reply: Fuel Pumps
