Lets talk aftermarket metering blocks for a holley.
670 CFM vac secondary street avenger on a cammed aluminum 5.3 in a light car
I can tell my transition a/f ratios are jacked without the wideband gauge on its way in the mail.
So knowing that I'll be working on these circuits do you guys think investing in a QFT or Proform metering block from the get go would be worthwhile?
Go ahead and enlighten me on the advantages of these over stock, I've been researching a fair bit but details even from the manufacturer are sparse at best
If all you are after is tunability then it is massively cheaper to drill out the stock metering block and make your own restrictors. You've obviously priced out the metering block, but have you looked what a set of screw in restrictors cost? You can get a bag of blanks for just a few bucks.
Besides, you might need to change an air bleed. So unless you want to upgrade the main body you might as well invest in a set of drill bits and bottom taps sooner rather than later.
Innovate use to have a user's forum with plenty of good write ups but they deleted it. In this thread below I detailed how I drilled out my Holley. Turned out nice. Hobby stores/ebay have the small numbered drill bits and pin vices. McMaster Carr sells brass set screws and bottom taps.
https://ls1tech.com/forums/carburete...-needed-3.html
Thanks for the replies guys.
I just got back from the first drive with the new wideband gauge. Readily evedent is the fact that for a "street ready" high performance carb the current state of tune is an absolute basket case of going from one extreme to the other as different elements of the fuel metering system comes into play.
It'll go from peachy idling in N @13.5 to lean in gear (15+), pig rich at a very light throttle cruise (11-12) to lean again at highway speeds (15-16) and back to pig rich at WOT (10 or so)
I've got my work cut out for me on this carb, but before I do I'm gonna try something unorthodox
