The Single Plane/Carbureted LS Engine Camshaft Thread
#82
Currious about valve events of this cam
First off, thanks and respect to speedtigger for compiling all of this info in one place.
I'm putting together a 6.0 for a swap into an ECSB 90 model GMC 1500. The known data of the combo is as follows:
Weight: Close to 5k with all the junk I carry around and Me in it.
Minus My big self and the tools, it should be @ 4450 after the swap..
Drivetrain: 4l80e currently has 3k stall, 3.73 gears 28" tall tires
Primary use: Daily beater! I'm fully prepared to replace valvesprings anually or Bi-annually..
Now for the motor:
I picked up an all aluminum 6.0 from a friend at a dealer, He had no clue of what it is, and after much research I "believe" it is an l76 from a '08+ "Vortec Max" truck.
It is a 6.0 that has dished pistons that have valvereliefs( It HAD vvt and dod, I've deleted both), and 823 heads.
I've aquired for it the following:
Vic jr.
Tsp cam and all supporting hardware, Cam is in the mail, so I don'tnhave a full card yet but here is what I've got so far. 231/246 .640"/.615" custom ground on a 108 lsa straight up with no advance ground in.
Planning to mill the heads .010"
Already have Cometic .040" gaskets
Pistons are out of the hole .005" quench should be .035"
Planning to run Fitech or Holley Sniper TBI undecided so far on which..
Don't have headers yet, I'm thinking 1.75 would be good or 1 7/8"?
Could one of You kind gentlemen please run this combo through Cam Motions calculators for Cam timing and Compression? I attempted to use them but I don't own a PC and rhey wouldn't jive with My Android device.
Also any ideas on what I did Right, or wrong or could do better I all ears for. This is not a race car, just a fun appliance to beat on and do burnouts..
Thanks!
Now for the motor:
Vic jr.
Thanks!
#83
Forgot to say cam is being ground on a 108 ICL.
Also, I know I've got to change My converter, as the one in there is for a Gen 1 sbc. I'm guestimating I'll need something between 36-3800? All ears on suggestions.
Also I'm sure more gear would help get this heavy beast moving but how much? I'm sure 4.56's would be the best acceleration, but will likely be miswrable on long drives as well as a really high driveshaft speed at normal highway speeds. Maybe 4.30's or would 4.10's be enough?
Thanks again guys even if Y'all tell Me the whole deal is terrible!
#84
Now for the motor:
Vic jr.
Thanks!
Now for the motor:
Vic jr.
Thanks!
As for the gear and converter, your heavy vehicle will benefit from as much gear as you can tolerate. The 4.56 or 4.30 would be great since you have overdrive for on the highway. For the converter a 3500-4000 will accelerate the vehicle best. The drivability of a high stall converter is subjective. So, it is hard for me to say how you will like that on a daily basis.
~Steven
#85
Steven,
Thanks for the reply, I'm sure Y'all are super busy and I appreciate the reponse!
I 100% expected to flycut the pistons with this cam, and will order the appropriate Lindy tool to do so.
As for the stall I knew I was gonna need something in that ballpark, I expect to run a 3,800-4,000 or there abouts. And I'm really considering 4.56's as sadly there is no 4.30 offered for My 454ss rearend.
I know this cam will benifit from more compression than I've got. This particular l76 came with dished pistons which I believe give a stock CR of 9.4? My plan is to mill the heads .010 and run .040 Cometics. Would rhis get Me to @ 10.0ish? or would I be better served scrounging up a set of lq9 flattops and going the same route with the milling and thinner gaskets, would this perhads get Me closer to 11-1 and halp it from being as soggy on the bottom end?
Also, in Y'all experience, how much is safe to cut stock GM pistons? This engine will likely not get sprayed, and if so, a 150 shot would give all the excitement I'd need Lol!
Sincere thanks.
Sincere thanks.
#86
Steven,
Sincere thanks.
Sincere thanks.
In regards to the nitrous, just remember that fly-cutting the pistons thins and weakens the piston above the ring lands. A weakened piston would be more succeptable to failure than an uncut stock piston. With that said, some customers are successfully doing this. Some others, not so lucky.
#90
Stock L96 6.0L long block with nothing more than dual spring kit, good pushrods, and VVT delete. I'm going to be running a single plane and 1 7/8" headers backed by a manual trans and 4.10-4.88 gears (depends on what car it ends up in).
I have a cam sitting around that is 250/266 @ .050" and .595"/.595" on a 112+4
There is not much chance it's going to fit without flycutting is there?
If push comes to shove I might just throw in a stock LS3 cam and run it.
#91
This is the one that you want:
http://www.cammotion.com/camshafts/s...ectangle-port/
#92
Looking for some opinions on a 233/233
Hi all from Australia.
I'm just looking for peoples opinions who might have run a similar setup to what I am about to build. what sort of power and torque did you make? How was drivability etc etc.
at at the moment my combo is:
LS1
233/233 111 LSA cam
double valve springs
Victor Jnr single plane high rise manifold
QuickFuel 750 dp
1-7/8 primary headers into twin 2.5 (probably) inch system
fully manual TH350
3.7:1 truetrac 9 inch diff.
When the time and money become available, I will have the heads ported.
Thanks in advance.
Nikolai
LS1
233/233 111 LSA cam
QuickFuel 750 dp
fully manual TH350
Thanks in advance.
Nikolai
#93
LS1
233/233 111 LSA cam
QuickFuel 750 dp
fully manual TH350
Thanks in advance.
Nikolai
LS1
233/233 111 LSA cam
QuickFuel 750 dp
fully manual TH350
Thanks in advance.
Nikolai
#94
Should be a nice little combo for you as long as the torque converter stalls in the 3000-3800 range. A combo like that with stock heads ought to make about 400 RWHP.
#96
Thats great news as far as I'm concerned. For now the heads are stock LS1. I've spoken to a machinist who is suggesting that with his porting process, we could squeeze and extra 50-60 hp out of it. But until I have the cash ready, he advised getting about 50 thou knocked off the heads for a cheap power adder.
#97
I think 40 horsepower is a pretty common result from a well ported cathedral head. Also, if you mill the heads, check your piston to valve clearance carefully. Typically when you mille a head .050", you also have to cut valve reliefs in the pistons to maintain adequate piston-to-valve clearance.
#99
Great thread LS1 tech has been a great help.
Looking for a cam for a stock 6.0 LQ4 unport 706 heads with spring ungrade.
I run this motor on an airboat so a little differnt then normal as the prop and gearbox are the limiting factor. Takes around 2500 to get on plane and the prop limits motor to about 5400-5800.
Going to use the bigger valves from 317 head in the 706's, dual plane intake and a 750 Holley DP with annular boosters. Low vacuum is not a concern and needs to be able to idle around 750 to be able to dock it.
Any comments would be greatly apperciated.
I have an NIB ASA Cam and BTR springs. Kind of like this setup but wondering what else you might recommend.
#100
I'm not sure you need more cam. 750 idle and 5800 peak almost says stock cam, but I know the ASA would work, though you are not getting near the potential out of it at such low RPM.
