Dist. Conversion Mechanical Fan
I know most of you arent in this situation, but i need to turn a mechanical fan/water pump with a dist. conversion. With the conversion moving the water pump forward, I have an issue
My research i have come up with a "dry sump" mandrel ATI sells then a pulley mounted on the end of it at the correct length. Any one else done this have any other way?
