Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
msd 6ls timing problem/question
Old 11-10-2014, 08:46 PM
jonz's Avatar
Default msd 6ls timing problem/question
Tried turning the timing up on my car from 32 total to 34 and it backfires leaving the starting line tried it all in at 2000 and 2500 no change and put it back to 32 no problem. Didn't have time to try and go other direction. Any ideas why it would do this? Bad sensor maybe? Idk
Old 11-11-2014, 12:30 PM
fast89stang's Avatar
Never had that problem.you sure all your grounds are good and you have a good 12 volt source? Mine loves lots more timing than that.
Old 11-11-2014, 02:26 PM
Old School Heavy
speedtigger's Avatar
That is an odd one for sure Jon. Are the plugs clean?
Old 11-11-2014, 02:28 PM
3pedals's Avatar
need a rundown of whole setup, that sounds like some kind of crazy problem....
Old 11-12-2014, 06:55 PM
jonz's Avatar
I haven't looked at the plugs but car drives fine and runs great and as far as I know ground is good same place my old 6al box was ground and direct to battery
Old 11-12-2014, 06:58 PM
jonz's Avatar
And here is my combo 3 pedals
Stock bottom end lq4 l92 heads milled tick custom ground cam victor jr. Intake and 950 hp with a power valve in the front with 76 84 jets like I said runs great with 32 no problems and 25 at idle and 32 all in at 2000 . Tried same thing with 34 idles and revs fine just back fires when you launch it fuel system is all magna fuel if that matters at all with 7 psi at carb I believe
Old 11-12-2014, 07:02 PM
jonz's Avatar
I know jets are on small side but seems to be rich just cus car tends to pick up as night goes on to cooler weather but I'm puzzled and racing is pretty much over guess I will check wiring again
Old 11-12-2014, 07:24 PM
3pedals's Avatar
What shooters in the carb?
Old 11-12-2014, 07:26 PM
Old School Heavy
I would pull all eight and just see what they look like.
Old 11-12-2014, 07:30 PM
jonz's Avatar
Got 35 squirters and will check the plugs
Old 11-12-2014, 07:36 PM
3pedals's Avatar
have you adjusted the accell pump linkage to eliminate all slack?
Old 11-12-2014, 07:38 PM
jonz's Avatar
Yes sent them when I put the carb on
Old 11-12-2014, 07:43 PM
3pedals's Avatar
how much stahl speed?
I like having my timing ALL IN either at idle or just off idle when a bigger cam is used. I'm guessing by the milled heads, that you put in at least a 230-240 cam?
are you running a MAP sensor?
can you take a screen shot of your MSD tuneup? try to get all the settings in the shot if you can
Old 11-12-2014, 08:06 PM
jonz's Avatar
Converter is way tight only 3600 needs 5500 which is in the works but cam is .626 .597 237 255 on 107+4 no map sensor and will try to get screen pic tomarrow
Old 11-12-2014, 08:32 PM
3pedals's Avatar
way tight converter is probably the cause, that is a BIG cam, it is NOT going to be happy below 4000 at all.
Old 11-12-2014, 08:38 PM
jonz's Avatar
Ya I just don't understand why have a tight converter and adding 2 degrees of timing would make it backfire tho?
Old 11-12-2014, 08:42 PM
3pedals's Avatar
that big cam with 107 LSA has ALOT of overlap, if you load it down too low of rpm bad things happen. not exactly technical answer I know, but its true.
Old 11-12-2014, 08:48 PM
jonz's Avatar
Makes sense
Old 12-15-2014, 11:54 AM
jonz's Avatar
Finally got back to the track after talking to msd wasn't the box but I was thinking it was just lean. So jetted carb up 2 in front and rear problem solved. Ended up liking 36 total. Went from a 6.93 to 6.88 with at the track with just changing the Jets and timing.
Old 12-15-2014, 11:55 AM
jonz's Avatar
Think it still needs alittle more fuel just have to wait till next year
Quick Reply: msd 6ls timing problem/question
