Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
PTV clearence issues
Old 03-30-2015, 06:05 AM
  #41
dogsballs's Avatar
Originally Posted by Doug G
DB, that's yours with the .100 shave ?
Not near as bad as I thought it would be...Almost makes me want to pull a head and look at mine....almost
Correct, 5364 rectangle heads
236/246 615/615 110
Old 03-30-2015, 03:48 PM
  #42
jerr6's Avatar
i measured assembled valve drop. 821 heads milled .007,.051 headgasket i got .
i got .210 assembled. i only have a digital caliper to use.
Old 03-30-2015, 05:49 PM
  #43
Old School Heavy
speedtigger's Avatar
Wow. That is quite a lot of room. Apparently the dished pistons make a nice amount of difference.
Old 03-30-2015, 06:44 PM
  #44
jerr6's Avatar
I founds online the dish measured .053 deep and I measured .051
Old 03-30-2015, 06:49 PM
  #45
TXsilverado's Avatar
Originally Posted by dogsballs
These are 70 thou cuts for ls3 valves
since we're posting pics. I had to hit my pistons with a grinder .090 to get .070 PTV clearance.
Old 03-30-2015, 06:57 PM
  #46
Old School Heavy
My quick math says those dishes bought you about .033" extra clearance over a flat top. That is a nice bonus for the guys running the LY6. So, you get something for the compression you give up.
Old 03-30-2015, 07:41 PM
  #47
jerr6's Avatar
Can u guys answer something for me. If some of my lifters are still pump up all the way does the valve spring pressure bleed them down?
Old 03-30-2015, 07:44 PM
  #48
Old School Heavy
Yes. They self meter. This allows them to adjust to a variety of preloads. That is why they do not need adjustment.
Old 03-30-2015, 07:48 PM
  #49
jerr6's Avatar
So if I was using a lifter that was fully pumped with checker springs to find PTV clearence my first test that's like adding length to the pushrod since the lifter didn't take any preload. That would make the valve open way more ?
Old 03-30-2015, 07:54 PM
  #50
Old School Heavy
You could probably successfully check the valve clearance with checker springs if you used an adjustable pushrod set at 0 lash. That is about the only way but, using a hydraulic lifter still adds a variable and some uncertainty.
Old 03-30-2015, 08:14 PM
  #51
checker springs with a full length pushrod would add whatever preload you have build into the pushrod measurement (assuming the lifter does not plunge). I measure using checker springs, a solid lifter, an adjustable pushrod set at zero lash and a dial caliper sitting on top of the retainer. this pic was playing around watching the base circle. it's really not necessary to use the gauge for base circle. stick your thumb into the pushrod and rotate motor and stop when the pushrod reaches the lowest point. use a junk gasket, snug down the head bolts, snug down a rocker at zero lash and mount the caliper onto the retainer like I have it on the pushrod. make sure to try and match the angle of the valve. rotat motor 2* at a time and push the rocker down and watch the caliper. it will eventually give you exact PTV measurements without playdough sticking to your valve, or falling off of the piston.
Old 03-30-2015, 08:52 PM
  #52
jerr6's Avatar
Hey guys thanks for all your help! I really appreciate it.
Quick Reply: PTV clearence issues
