Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
First time at track with lq4 build
Old 05-29-2016, 07:25 PM
toxic99's Avatar
Originally Posted by Racereg76
Quick update guy thank you for your input now I have a good starting point went to the track again today I bump the timing up to 34 degrees and gap the plugs to .45 and the car picked up went 11.52 first time shot shifting at 6000 rpm
Nice progress...but you need to rev that thing. 6k isn't even tickling that motors peak power. Jmo
Old 05-29-2016, 07:42 PM
Dragway's Avatar
Are you guys use a map sensor?
Old 05-30-2016, 02:12 PM
jerr6's Avatar
i have it hooked up. found out it wasn't working so have been running without with no problem.just make custom timing curve
Old 05-30-2016, 03:10 PM
zraffz's Avatar
Wow you shaved .6 off your ET so that really woke it up! What was your trap speed?
That should be able to outrun your old 383.
Old 05-30-2016, 06:50 PM
sbdgbody's Avatar
wow big improvement yes what mph
Old 05-30-2016, 06:59 PM
Racereg76's Avatar
My trap speed was 116 and I'm going thru traps a 6200
Old 06-05-2016, 11:26 AM
TXsilverado's Avatar
give it some RPM if your valvetrain will handle it. there is some left on the table with rpm alone.
Old 06-05-2016, 09:37 PM
In-Zane Moderator
ZONES89RS's Avatar
Way more left in it. Crank the engine to shift at 6800, let it eat and get back to us. You will be surprised.
Old 06-06-2016, 08:28 PM
Racereg76's Avatar
I gonna try shifting at 6800 i have stock rods with arp bolts how high can i safely spin it
Old 06-06-2016, 09:59 PM
In-Zane Moderator
ZONES89RS's Avatar
I have spun so many to 7200 it isn't even funny. All with stock bolts in the rods. Set the rev limiter to 7000 and shift at 6800. Just be ready, you gonna have a sore face from all that grinning getting to feel the rest of the horse power you have been missing.
Old 06-08-2016, 10:57 AM
I spun my last stock bottom motor to 7,500 a few times by mistake no problem. I typically shift all motors between 6,800-7,200 RPM depending on the top end.
Old 06-12-2016, 12:28 PM
  #32
Old School Heavy
speedtigger's Avatar
With that cam, it will run better shifting at 6500 or so.
Old 06-12-2016, 03:18 PM
  #33
hell, i've shifted a stock cammed 5.3 to 6500 before and i'm still the only one i know of to put a stock cammed 5.3 into the 13's with a full size extended cab silverado. 13.88 like 10 years ago...even before they started sticking 243 heads on a 5.3
Old 10-13-2016, 08:12 AM
  #34
jaywill's Avatar
Originally Posted by TXsilverado
What does your timing curve look like? my best times came from a flat timing table. It also drove better on the street like that.
not to hi-jack but do u have pic of your cruve ?
Quick Reply: First time at track with lq4 build
