Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
vic jr to super vic
Old 08-23-2016, 12:33 PM
Old School Heavy
speedtigger's Avatar
Originally Posted by fast89stang
That's kind of what I have heard, but if my spacer and Jr works this good, Im not sure if its worth the cost to switch.
You have rectangle port heads don't you?
Old 08-23-2016, 09:47 PM
windmill's Avatar
e test and tune was a bust would not run slowed down 3 tenths,, 6.8's but close passes tho the super vic will go on and change back to pump gas back like it was,,,, will tell some info prob sunday.
Old 08-27-2016, 12:53 PM
windmill's Avatar
well today is going to be nice to race,,, ill know tonight if the intake picks up any,,
Old 08-28-2016, 08:35 AM
windmill's Avatar
Well the super vic ran the same as my vic jr. now going to try a bigger carb
Old 08-28-2016, 07:39 PM
thirdgenbum's Avatar
did you do any jet changes after the intake swap?
Old 08-29-2016, 01:50 PM
windmill's Avatar
no, ive traded my pro systems e85 carb for 950 pro systems carb gas. I'm going to try it tomorrow night and see what that does,,
Old 08-31-2016, 07:28 AM
windmill's Avatar
well the new carb with super vic intake, best pass after weather cooled down 1.44 at 6.48..... I getting to think the super vic is to big for what I have.. I'm going to not touch carb and put the vic jr back on for this weekend race..
Old 08-31-2016, 05:27 PM
Old School Heavy
Interesting. Perhaps if you had ported or aftermarket heads and/or a higher RPM range, the Super would start to show benefits for you.
Old 09-01-2016, 05:02 PM
crossbreed383's Avatar
Or maybe if the Super Victor wasn't such a bag of S%t out of the box it would have worked
Old 09-01-2016, 06:30 PM
Old School Heavy
LOL! Don't sugar coat it.
Old 09-03-2016, 12:16 PM
flyin's Avatar
well then.....
Old 09-03-2016, 09:50 PM
  #32
Chris05's Avatar
Speedtigger, what mods did you do to your old Vic jr ?
Old 09-05-2016, 12:59 PM
  #33
windmill's Avatar
i put vic jr back on seems to work just as good on et's as the super .. I think I need to change heads ..
Old 09-05-2016, 06:00 PM
  #34
Old School Heavy
I opened up the ports a bit. I was using CNC ported heads that had a lot more cross section. So, I did not want to have less cross section in the intake.
The challenge that I had with the cathedral Vic Jr. is that the cross section of the ports at the plenum were the same as my cylinder head's port entry cross section. So, when I was done, there was no port taper left in the intake manifold. It would have been pretty easy to add some port taper to the center cylinders, but would have been pretty tough to do on the outer cylinders due to the port size, port curve and plenum access.
Old 09-06-2016, 11:55 AM
  #35
fast89stang's Avatar
Yes, 823s.
Quick Reply: vic jr to super vic
