post up your NOS combos & results..
99 jet ?
Damn !
Results
The Fuel jet size should be 0.097" or 2.457mm
A Nitrous jet size of .099" or 2.5146mm should produce:
442.62 HP with 1 port(s)
Actual HP to the wheels: 376.23 HP
Damn !
Results
My old sbe 6L
0.28 jet
32 base pulled 12 (I think)
9.41
142.7mph
Thread for sbe
https://ls1tech.com/forums/carburete...4-nitrous.html
New motor 416 LSX
.032 jet
8.78
153mph
0.28 jet
9.41
142.7mph
Thread for sbe
New motor 416 LSX
.032 jet
8.78
153mph
My old sbe 6L
0.28 jet
9.41
142.7mph
Thread for sbe
New motor 416 LSX
.032 jet
8.78
153mph
0.28 jet
9.41
142.7mph
Thread for sbe
New motor 416 LSX
.032 jet
8.78
153mph
SBE 6.0,LS3 Heads, Tooley cam,Supervic,4150,I/S Plate
5.83@118 so far on a 73 jet - 60 ft is off - If it goes in the mid 1.20s on a good track should have been a hi 5.77-5.78 pass
3000 pds @ 6000ft of D/A
Not my car but I help build it and I get to drive. Cheapest racing I have ever done :-)
Stock Cubic Inch 6.0L with Ported LS6 Heads
3260 lbs
Stinger plate with 99n and 70 fuel set at 5 psi
NGK 9s gapped at 28
18 degrees timing
116 octane
60 foot: 1.25
1/8th Time: 5.68
1/8th MPH: 117 (Smoked the converter)
3260 lbs
NGK 9s gapped at 28
18 degrees timing
116 octane
60 foot: 1.25
1/8th Time: 5.68
440 ci lsx block
World products ls1 cathedral port heads
Mast intake 1100 cfm dominator carb
.110 jet in nitrous outlet stinger 1 plate
1.210 60'
5.14 @ 136mph
3100 lbs
120 nitrous renegade fuel
Timing 14 degrees
-10 NGk plug
1.210 60'
5.14 @ 136mph
3100 lbs
Timing 14 degrees
-10 NGk plug
