Help with carbed 5.3
5.3 with prc 2.5 heads, victor jr single plane, comp 232/238 cam, 750 aed carb. Im having a issue with pop and fire out of the carb when going into the secondaries. It runs and revs great on primaries but if you stab it a ball of fire comes out carb then it seems to accelerate good after it pops if you stay in it. Any ideas?
sounds like a lean condition. Check your accelerator pumps and make sure everything is working accordingly. Also try cleaning the carb passageways really well too. I was getting a bad miss going into my secondaries, turned out I had trash in the secondary squirter causing a bad miss when transitioning to WOT
