Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Camshaft help or opinions
Old 11-21-2016, 01:08 PM
79buLS's Avatar
Default Camshaft help or opinions
Ok this is my first LS build.
I have a drag car only and I am going to build a 5.3 carb setup on pump 91 gas. N/A.
My car is a 79 malibu that runs a glide 5200 stall, 4.56 gear, 28" slick, long tube headers, and will weigh 3000 with driver ready to run.
I have a Victor jr, 750 carb,243 heads and a 5.3 short block.
My goal is 400 to 425 at the crank.
This is a N/A set up and will NOT see boost or NOS.
What do you all recommend to get the job done or can it be done.
Need to do it with a 5.3 because of a claimer series I will be running.
Thanks for any advice or help.
Old 11-21-2016, 06:32 PM
LQ4BU's Avatar
Your best bet would be to contact any of the well known camshaft companies for a recommendation that will fit your specific setup and needs.
Just to mention a few....
http://www.bulletcams.com/
http://www.cammotion.com/
https://www.texas-speed.com/
http://www.engpwrsys.com/
If you plan on using the stock rocker arms, you definitely want to upgrade them with the improved trunion kit.
https://www.texas-speed.com/p-361-co...s-engines.aspx
Old 11-22-2016, 11:37 AM
79buLS's Avatar
Thank you I have actually talked to 3 out 4 you have listed. I just wasn't sure if a factory cam would fit the bill or if I would need to go custom.
Old 11-22-2016, 02:16 PM
LS1Tech Sponsor
CAMMOTION PERF's Avatar
The camshaft that I suggested for you will do very nicely. Share some video of a few passes when you get it done.
__________________
The Switch Is On To Cam Motion!
40 years of Championship Winning Experience • Superior 8620 Steel Camshaft Cores • Quiet, Smooth & Powerful Lobe Design • Virtually Unlimited Lift and Duration Combinations • Finish Polished For Quiet Operation • Cam Doctor Printout With All Cams
The Industry's Best Customer Service
www.CamMotion.com ☎ 225-926-6110Like Us On Facebook!
Quick Reply: Camshaft help or opinions
