Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Catalytic Converters
Old 04-22-2010, 06:04 PM
RobRomero's Avatar
Default Catalytic Converters
Hey All,
I was getting SES lights for faulty O2's so I went ahead and replaced all 4 of them. Everything was fine for about 2 weeks, but now I am getting an SES light from my Cat's I guess I shouldn't be surprised since the O2's and Cat's were all stock. So......now I am checking to see if anybody on here has reasonably priced Cat's they would like to part with???
Old 04-22-2010, 06:23 PM
WSsick's Avatar
just gut the *******. itll sound better. get some more mods and tune it and no more SES light
Old 04-22-2010, 10:24 PM
94lt105's Avatar
Ya, gut em and tune em out bro!
Vince
Old 04-23-2010, 06:11 PM
RobRomero's Avatar
You every done it? How much time does it take. I have heard a lot of ppl say it makes the exhaust all raspy, is that true???
Old 04-23-2010, 06:19 PM
RobRomero's Avatar
I Was researching and found this...
Do not "gut" the cats. There are several reasons not to do so. Especially if the engine is still normally aspirated. They are as follows:
The major one being that the current generation of catalyst elements are not very restrictive at all. In fact, they actually work like a tuned collector on normally aspirated engine. As the exhaust gases pass through them, they act like a check valve for exhaust flow. As the exhaust valve closes, momentum causes the gases to continue to travel through the exhaust system. This is plenty of energy to pass through the cats. This causes a vacuum to build up between the exhaust valves and the catalytic converter. The energy required to pull the gases back through the element can't build fast enough to work before the next exhaust valve opens. When that next exhaust valve opens, it is opening to a vacuum environment which helps to PULL the gases out of the cylinder due to what is called "scavenging effect". This translates into more power as the piston now does not have to do all the work to evacuate the cylinder of spent combustion gases.
Second, if you were to remove them, you would definitely want to use a cat removal pipe. The chamber left after you would "gut" the cat is actually worse at losing energy than a catalytic element (understand I mean element designs after around 1990). This is because as the gases enter the empty chamber, exhaust velocity slows down. As it then regroups to enter back into the exhaust piping, it does not have the energy it did before, therefore it "stacks", causing backpressure. This backpressure now works against the flow of spent gases out of the cylinder when the exhaust valve opens, causing the piston to do all the work. Now, energy is being wasted for gas removal that could otherwise be used to turn the crankshaft.
My recommendation would be to leave the cats alone and concentrate of every other part of the airflow system. After all else is done, come back to them, and if not using a high flow catalytic converter, then use a cat-delete pipe.
Shawn @ Street Sports
.......don't think I am going to gut mine.
Old 04-23-2010, 06:26 PM
blk/slvr02ss's Avatar
U can get a off road y-pipe from Mac for $199 and that will solve your problem.
Old 04-26-2010, 06:10 PM
RobRomero's Avatar
Sickkkkkkkk. Can you PM the link?
Old 04-26-2010, 06:13 PM
It has been 5 yrs now since i bought the off-road y-pipe so i would say just go to Mac exhausts web site.
Old 04-27-2010, 03:59 PM
buddyleex's Avatar
If you want to pass visual inspection if you are worried about that, then:
http://www.siliconeintakes.com/produ...4df56b3ffd94f0
Old 05-02-2010, 05:10 PM
indyparts's Avatar
Buy replacement pipes and sell me your OEM cats for $95 shipped!
Old 05-04-2010, 08:53 AM
twozs's Avatar
you don't mention what year your car is but 2000 - 2002 F bodys the cats have an extended warranty of 10 years or 120,000 miles. i just had my 01 z28s right cat replaced for FREE
Old 05-04-2010, 09:09 AM
Nightrydass's Avatar
x2 i did mine last yr before i put her way for the winter. It was either that, or i spend $1,500 on some Kooks and a catted-y (NJ). If i had to BUY the cats, i wouldnt buy 2 not just one, they're $500 a piece, and i would not dump that into stock ****. lol.
If it's free, its for me!
Old 05-10-2010, 04:27 PM
RobRomero's Avatar
Hmmmmmmm Something to think about.
Old 05-10-2010, 04:29 PM
RobRomero's Avatar
My bad. An 02', but I'm already over the 120k miles.
Quick Reply: Catalytic Converters
