Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
School me on battery relocation!
Old 04-25-2012, 10:33 PM
2 fast 2000's Avatar
Default School me on battery relocation!
I have a 2000ss camaro with a LS3 swap. Relocated the battery to the back & now it takes a while to start. I think a ground is missing or not right. How should everything be run?
Old 04-26-2012, 07:34 AM
Nobody???
Old 04-26-2012, 07:36 AM
I've tried a search. Is there a diagram on how to wire and run it correctly!
Old 04-26-2012, 07:52 AM
3rdgentug's Avatar
basically relocating a battery is the same in a car no matter where you put it.
it needs a good ground and a good size cable to the ground and going to power.
check all connections , then check your battery if its not reading atleast 12.5 then thats part of your problem
Old 04-27-2012, 07:14 AM
The battery was the first thing I checked. But there is something different about routing the cables when relocating the battery. I've read it on here before but can't find it on the search.
Old 05-12-2012, 01:33 AM
bmf5150's Avatar
I ran two 4 guage from trunk to engine ,one positive and one ground direct to block!
Old 05-12-2012, 06:22 AM
Doug G's Avatar
Slow cranking ???? What size are your battery cables ?
Longer amp draw from battery to starter requires bigger cable.
Old 05-12-2012, 07:16 AM
maxharvard's Avatar
My wires are 00 (double ought) sized. Work just fine with an LS3. Even with the negative cable only being a foot long and going straight to the frame.
Old 05-12-2012, 12:23 PM
Doug G's Avatar
00 here also (welding lead)....and cranks just like it did before the re-location.... ground in trunk and motor is grounded to sub-frame (with weld-in connectors)
Old 05-27-2012, 04:49 PM
pkincy's Avatar
Likely the OP didn't use welding cable and he is getting too much resistance front to back.
I have heard of it working with No 4 cable, but not reliably.
Remember when Lingenfelter built that car and took it to a magazine shootout and lost the spark at speed on a road course and smacked the wall?
Jason finally chased that down to a too small positive cable to the relocated battery as I recall.
Perry
Old 06-03-2012, 09:51 PM
Turb0Z28's Avatar
Did mine and now it will not charge
Quick Reply: School me on battery relocation!
