Ok, I have been told that ls1 and ls6 have the same throttle body, but i found publication that states different, so what should i believe, if i had a caliper I would measure it myself
well... the ls1's in the vette were electronic whereas the f cars are cable... so its not a direct bolt on switch from vette to f car type... but the TB bore size is still 78MM. the Z06 had a larger MAF
