Strange noise at warm start up?
Below is a video I got of a weird annoying noise that occurs sometimes when my car is warm and is started back up until it's back to running temp. Doesn't do it when the engine is cold or if it's still hot.
I was thinking it might be the AIR pump, or something else emissions related? The sound also comes out of the exhaust. In the video you hear it, I rev the engine a little and it goes away but comes back at idle then completely goes away. Usually takes a minute or two once started up for the sound to go away.
I would warm the car up, shut it off then remove it completely and try starting the car.
It won't hurt anything, all it does is pump air into the exhaust manifolds to help warm up the cats for emissions reasons. Some say it also helps prolong the life of the cats by helping them get up to temperature faster
Same happens on my '99 z28. I never thought it was abnormal. Perhaps one of these search results will help?
Major Symptoms of a Failing Fuel Pump (or filter)
There are four signs of fuel pump malfunction that are easy to figure out. It is not necessary that all four should be present; you need to act fast if even one of them occurs.
One of the two biggest symptoms of a malfunctioning fuel pump is overheating and the consequent stalling. If the pump gets heated within a few minutes of turning the car on, it needs to be replaced. A bad pump will also show signs of intermittent breakdown; it will work for around 15-20 minutes and then stop working. Once the vehicle is allowed to remain idle for around 30 minutes so the engine can cool down, the pump functions normally. That is not, however, the solution, as the pump will stop working every time it overheats.
The second biggest symptom is the sound the engine makes while starting, especially during cold starts. It's like the engine is screaming or screeching. The sound will always occur when you start the car, but stops once the car has started. If you can get someone to help you out, put the key into ignition without starting the car, and have your friend stand by the gas cap and listen for the sound of a running motor. If he doesn't hear anything, your fuel pump might be bad.
If your car loses power while climbing up on slopes, it could again be the fuel pump that is failing. It can't provide the additional gas the car needs to go ahead without losing speed.
If the flow to the fuel injection system is not constant, the engine may develop problems. Signs include a hesitant start or a stumbling problem on ignition. If small, unwanted debris or grainy particles enter the pumping system it can cause a breakdown, thus, abrupt stopping of a vehicle can also be considered a symptom. If the filtering mechanism develops a problem or gets struck up with impurities, the engine will show symptoms like rough firing and fickle working.
Read more at Buzzle: http://www.buzzle.com/articles/sympt...fuel-pump.html
I guess it's time to delete my AIR pump and get the code deleted, along with the cats!
