Header/Y Pipe Help
Header/Y Pipe Help
So I'm ready to make the next move and get a set of longtubes. I have done a little bit of research and I've partially decided on TSP 7/8 and the TSP cattless y. I've heard a few bad things like "welds dont hold up" and "rattles". Whats your experiences with that? And on a side note, will the above set up work with Magnaflow cat back?
98 Camaro SS
98 Camaro SS
I have the TSP 1 7/8 and catless Y
Issues:
Rubbing on kmember (even after grinding lots and new motor/transmission mounts. Drivers side is piece of cake to grind to get enough clearance, passenger side is needing more on top of k versus on side in my case
Ypipe.....IMO a royal POS... fitment is HORRIFIC and even worse is you cant slide everything "tight" in each joint or you will never get it to line up with the merge to the ipipe connection. I have tweaked and manipulated mine to get it decent however its still not perfect by any means
Have seen no weld issues as of yet. Did get lots of "discoloring" that is not normal with Stainless however TSP blames me and stated it must have got something corrosive on it. Not sure how "water" is corrosive however what do you expect for lower end headers and ypipe
Issues:
