LS2 swap drive by wire problem
Old 10-17-2008, 12:36 PM
Najania's Avatar
Exclamation LS2 swap drive by wire problem
Hi. I just started up my LS2 for the first time. It just started right away. very nice.
However, there is a problem. The car wont take the throttle. The gaspedal is hooked up with the conector, but nothing happens when i step on the throttle?
Do any of you have any idea of what is wrong? I have tried to find the problem but can't seem to find it by myself--
When ignition is on, the throttle body opens just a bit to be able to idle. But nothing happens when i step on the gas pedal.. Frustrating.
In advance, thanks for the help.
btw, is all from gmpp and new. Engine, wiring harness, and ecm so on.
Old 10-17-2008, 12:40 PM
01WS6/tamu's Avatar
Need to scan it and see what DTC's it has before you can begin to guess what is happening. Double check all of the connections and make sure you did not accidentally bend a pin sideways when you pluged in the connector at the gas pedal or throttle body.
