mustang ls1 swap parts list
would really depend on where you drive(city or highway or both) and what you really want to compromise either on the street or at the track.
I wouldn't use much more than a 2800 which is going to stall around 2400 on a foot brake, a triple disk, but that's just me.
SBC is small block chevy. you need the third ones on dynatechs site for LSX headers
i have a yank SS 4000 and drive alot of combined city/highway and i have no regrets. it cruises nice on the highway with the 373 gears, gets about 18-20mpg and so far ive managed a best 60 ft of 1.46 on radials with a cam-only motor. i made my own trans crossmember.
ive got the aje ls1 swap kmember and there th400 transmission crossmember. if u go this route plan on waiting about 6-8 weeks. also plan on spending 600 bucks on all of it after shipping.
so anyone know what i should use for a drive shaft what slip yoke pinion yoke ect???
i heard i can just use a stock 5.0 drive shaft for a 6-speed
what can i use for a th400 or 4l60E????
help
Thanks Jorge
help
Thanks Jorge
im running a 4000 protorque converter for my th400. i got the crossmember from aje racing. It will be a street strip car but mostly driving down the street going to the drag strip lol.
#32
CROWDER how does it drive on the streets and highway???
do you know if aje makes a cross member for a t56 ls1 swap
i think iam going to use a six speed cause its going to be my daily driver took me about a month to deside this
any tips i should know about for doing the 6speed swap would really help and what i need to order
what drive shaft set up would be best for this im running a 94-98 5 lug rear end w/ disc brakes
could i just change the yokes and u-joints???? help info please
Thanks jorge
Thanks jorge
#34
Couldn't you just open up the hole for the clutch fork in the bellhousing and use a 03-04 Cobra clutch fork/Throwout bearing and keep the cable clutch setup? The boss should be on the transmission front cover for the pivot ball, just needing drilled and tapped. You could look into using an 03-04 Cobra yoke as they also came with T-56's and the output shaft should have the same spline count.
#35
i would like to use the cable clutch has anyone done this or working on this????
i think the clutch fork would hit the kooks headers I THINK??? headers would be the way i read it somewhere but really dont remeber the facts
#36
What does SBC means?
http://www.afabcorp.com/AFCO_Dynatec...y_Code=dragaje
and will this headers work with QA1 k-member?
