GTO oil pan and LQ4 truck pump compatible?
I put the LS1 GTO pan and pickup tube on the '03 LQ4 I am swapping into the Mercedes on another thread. I noticed that the pickup tube was very difficult to get into the pump. It went in but seemingly much harder than it should. Is there a difference between the LS1 pump and the Truck pump? I was concerned about messing up the o-ring, and having the pump suck air. I swapped pans a couple of weeks ago, and havent fired the engine, but was thinking of taking the engine out to check it before the fire up.
I will be doing a cam change before fire up and was thinking I may be able to see any pushed o-ring without taking the pan out. What do you think?
Well, good thing I took it out, it had two o rings in it. I didnt pull the truck o ring out and placed the GTO tube in. Probably wouldnt have worked too well. Thanks for all the replies!
