ls1 and t-56 g-body
Old 04-30-2009, 11:56 AM
80bu's Avatar
Default ls1 and t-56 g-body
I need some help on a ls1 6speed swap in a 1980 malibu.I have a donor car wich is a 2002 ss camaro.Do i need the clutch pedals, fans radiator?What abount the slave cylinder? Any help on this swap would be greatfull.Thanks David
Old 05-01-2009, 04:52 PM
80bu's Avatar
Nobody on here has done this swap?
Old 05-01-2009, 05:16 PM
Navy Blue 01 B4C's Avatar
Here is a link to the swap that 388bu did.
https://ls1tech.com/forums/conversio...-complete.html
Old 05-01-2009, 11:49 PM
sawzall wielding director
G-Body's Avatar
You can use the f-body rad if it fits, otherwise the malibu one should work just fine. Use the f-body fans if they fit, or I used fans from a mid 90`s FWD 3800 car cause they fit and were cheap, just had to make mounts. Mines an auto so I don`t know about pedals fitting but I would think the f-body pedals would be a start, just get a sawzall and welder
Old 05-02-2009, 12:34 AM
71 chevelle's Avatar
If its a donor can and not going to cost more to pull the part pull them you are better off having them and not using them then needing and not having them.
Old 05-02-2009, 07:07 AM
80bu's Avatar
Thanks guys, i just wanted to make sure i got everything.
Old 05-03-2009, 03:01 AM
88SS LS1's Avatar
I built a custom clutch pedal off of the stock monte pedals, by using John b's design to make mine. Here is his website for the swap
http://www.ls7montess.com/
Quick Reply: ls1 and t-56 g-body
