84 C10 a/c help needed
Old 05-13-2009, 05:28 PM
ad53030's Avatar
Default 84 C10 a/c help needed
I'm trying to wire up the a/c in my 84 w/ a 5.3 from an 07 Silverado. I wanted to reuse the factory low pressure cutoff switch on the dryer. There are two wires coming out of the switch - one + 12v & a second that should complete the circuit and activate the switch. My question is where should that lead be wired to? I was told to connect it to the relay for the a/c comp but I don't know which of the four terminals to connect to. I'd rather wire it into the relay than directly to the compressor as the engine harness is factory and I have a relay center near the ECU (as wired by current performance wiring).
Old 05-14-2009, 12:35 AM
N21923's Avatar
What ECU are you using? Are you using DBW or cable?
Old 05-17-2009, 09:37 PM
ad53030's Avatar
Using stock 07 truck ECU (DBW).
Old 07-21-2009, 03:50 PM
fast400's Avatar
The low pressure switch should have (-) voltage on both prongs. It simply completes the negative circuit to the compressor once the switch closes (pressure is good)
Quick Reply: 84 C10 a/c help needed
