List for a donor vehicle.
Old 05-19-2009, 03:54 PM
mach.80's Avatar
Default List for a donor vehicle.
Would anyone care to tackle a list of items I would need from a 2005 or newer Chevy 2500hd donor vehicle.
I plan on swapping the 6.0 & 4L80E into my 85 Grand National. I would like to keep the A/C and cruise control. I would also like to incorporate the factory truck guages and a/c control unit into the dash of the GN if at all possible.
This will be Turbocharged with a PT 75mm of some sort. Details to be hammered out.
Also, if you have any recommendation on the trans x-member, engine mounts, or accessories ie. altenator, power steering pump and rack, and a/c compressor, please don't be shy.
This will be a budget build. However, I am fully aware it costs quite a bit of coin to build a turbo V8. But I was always told " the way you eat an elephant is one bite at a time".
Thanks,
Joe
Old 05-19-2009, 09:59 PM
IntercooledC6's Avatar
Good luck on you new build....
Larry
Old 05-19-2009, 10:01 PM
mach.80's Avatar
Thanks It should be a blast.
Old 05-20-2009, 09:04 AM
dpd069's Avatar
This isn't a complete list but here;s a few things I'd think about-
Wiring harness complete and uncut including the fuse box
PCM
TAC module, harness and pedal assembly (make sure these and the PCM come off the same truck)
Electronic throttle
Radiator and condenser
fuel lines
fuel pump assembly
MAF and air inlet elbow
Accessories - unless you are going F-body for hood clearance
Power steering and AC hoses (you might need the ends to make custom hoses)
Engine and transmission mounts - don't know if you need them
If you are not going to use an electronic throttle, you will need another PCM with the drivers in it for IAC and a throttle body complete
Old 05-20-2009, 03:03 PM
kirtondog23's Avatar
I would get engine and tranny cooler lines, I did not have them in my swap.
Headers? not sure since you are doing turbo,
O2 sensors
shifting linkage (just in case it will line up.)
Old 05-21-2009, 02:30 PM
mach.80's Avatar
Default Cool
PCM
Electronic throttle
fuel lines
fuel pump assembly
Great! Now were talking.
I plan on incorporating the factory guages so having the fuel pump assembly including the sending unit is a great idea.
You had mentioned a TAC module. Is that the controller for the transmisssion?
You had also mentioned the Electronic throttle. Besides the pedal and the throttle body is there something else that fits in there as well?
Thanks,
Joe
Old 05-24-2009, 12:46 AM
BandAid's Avatar
Thanks,
Joe
glad you made it here from Tb.com
I have an 85 g body also,I have a 5.3 2005 tahoe motor ,I am yanking all the junk (electronics from it)except coil packs..carbing the motor with a CSU blow thru turbo carb,$900 for the carb,4 barrel intake $350,....I am on budget build also...msd6010 to run coil packs...gonna be different..
Quick Reply: List for a donor vehicle.
