3 wire -> 1 wire Oil Pressure Sensor?!
Old 05-28-2009, 05:35 PM
TurboBandit's Avatar
Default 3 wire -> 1 wire Oil Pressure Sensor?!
Hey guys,
Swapped an LS1 into my 2000 S10, and a nice t70 turbo on the back of it.
The engine is out of a 98 vette. It has the 3 wire oil pressure sensor.
My harness from Current Performance (made by Jared) has a single wire o2 sensor plug.
Can you connect the single wire to one of the 3 wires in the 3-wire-Sensor to make the gauge work?
I don't want to have to go buy a new sensor...
3-wire sensor has:
Grey wire= 5 volt source
Tan/wht wire=Signal
Blk = Ground
Right now, i have it Tee'd into the Tan/wht wire. Oil pressure guage is pegged (reading 100+psi) without engine running.
Can this be done? hookin it up to one of the other two wires?
Old 05-28-2009, 06:35 PM
S10xGN's Avatar
Originally Posted by TurboBandit
...My harness from Current Performance (made by Jared) has a single wire o2 sensor plug...
Excuse me, I'm not understanding how this relates to oil pressure?
As far as the oil pressure sensors go, why not just adapt the S-10 sensor to you LS block? Then the gauge will read as intended.
Russ
Old 05-30-2009, 12:58 AM
Russ
Way different threads. The S10's threads are way too big. The LS block's threads are very small.
Old 05-30-2009, 02:42 PM
S10xGN's Avatar
IIRC, the LS sender has 16mm threads (that's over 1/2"). Don't remember the thread size on my '96 S-10 sender, but I had no problem adapting it to the 3.8L Turbo-Buick motor that now resides there. There's likley an adapter to be had, or made... Have you tried contacting the harness maker?
Russ
Old 05-31-2009, 01:37 PM
ForcedInduction's Avatar
just buy a single wire sensor from a gen III engine out of an older silverado. same resistance values....problem solved.
Old 01-15-2019, 08:51 PM
Seanbobo's Avatar
does that actually work for an s10 system
Quick Reply: 3 wire -> 1 wire Oil Pressure Sensor?!
