Another turbo 5.3L fox notch drag car
#141
I also need to look into upgrading my rear brakes, maybe a twin caliper disc setup. (running stock drums now) when im staging i start foot braking it a few feet before the staging beams to prespool the turbo a little before being fully staged and hitting the trans brake. the problem is im on the brakes hard as i can and when it starts making torque it blows right thru the brakes. so i end up having to back petal the throttle (which looses all my boost) to stop before red lighting and i dont want to be rolling while hitting the t brake button so then i have to start building boost all over again. The only other thing im thinking i can do to try and help with this is to pull more timing out while the t-brake/launch control button is in. its at 0*deg timing while button is in and with in 1000 rpm of launch limit rpm. i want to try pulling it down to -5*deg to see if it will spool a little faster one on the t brake. just need to play around with it more.
#142
Ordered and waiting on adjustable rear lower control arms and the weld in threaded rear coil perches that work with coil over style springs. Need to be able to adjust more at the track to get it to 60' like it should. What setup are you running on the rear of your car?
I have adjustable upper and lower control arms, UPR adjustable sway bar, stock springs and autozone shocks. Running 28x10.5 ET drags. I think that is it. My setup went 1.34 and 1.35 with a launch from 1-2k rpm. I think it will do a bit better off the t-brake with some more RPM.
#143
Pulling a bit of timing out of your setup should help. That small staging window is a bitter harder to work with when you have some power to contain at the same time.
#145
Little update. Ran the car at two tracks this wknd. Friday night at qualcom stadium parking lot 1/8mile drags first pass off the trailer it goes 6.11@113 which is my new personal best. Then Sunday went and got my nhra license passes out of the way up at barona drag strip. The last two full passes were 6.26@111mph and backed it up with a 6.25@112 running 12psi boost on all those passes. Best 60' sofar is 1.42
#151
Question
Hey man me and another guy over here are really looking for some info on how to get our LSx motors running on Megasquirt likeyourself.
Do you think you could do a write-up or help get us going down the right direction.
I've read a ton of the megamanuals but would be really nice to see someones writeup on how there doing it.
https://ls1tech.com/forums/pcm-diagn...l#post15378140
#152
(71 chevy) I don't know I have not put it on scales yet. I would think around 2900-3000 if I had to guess.
(bigamil) I'll see what I can do. What is it your needing info about?
#155
I was raising my 2 step rpm and put a little more air in the tires. And it kept going quicker. I was going to go for one more pass and try to get a high 5.80 out of her but the track closed early because of how few cars were running. The track prep was on point this wknd.
#156
#158
(Tireburnin) oh you mean my chunks of rusty steel drilled out and used inplace of a heim joint sway bar end links. Well those are what we call "custom" haha
(71chevy) Yes but there is a little strip that has to be added to fill a gap left.
