2004 LS1 GTO harness connector identification
Old 04-26-2010, 09:15 PM
DJBLS1's Avatar
Does anyone have a part number for the C206 body connector? I have been in to the dealers today and they could not find it on their microfiche.
Are there any other GM cars WITHOUT the LS1 that uses this plug? maybe i can get one at the local pull a part. I know they do not have anything LS powered
Old 04-28-2010, 10:10 AM
SamHatco's Avatar
Originally Posted by sum guy
I'm using 2004 gto stuff too. Looks like the bcm controls the low speed fan and pcm controls the high speed. Any one figued out a way to run a low speed. Thing of wiring it to an unused out put such as ac, evap, egr and tune it to activate at certain temp. Any other ideas.
I used the 04 GTO pcm, bcm, pim and throttle control. I used a two speed Lincoln Mark VIII fan and wired the low speed wire from the bcm to the low speed relay and the high speed wire from the pcm to the high speed relay. Works perfect.
Mark VIII fan on my 69 bird. Has never been on high speed yet. I also got the Hollister relay system. Very well made product here are a few pics.
Mark VIII two speed fan
Hollister Relay setup. This is a really robust system with high quality relays and wires. They added an extra relay to activate the fan when the A/C is on
Installed with a PRC radiator
Sam
Old 04-28-2010, 10:20 AM
69 Ghost's Avatar
I was going the Mark VII fan route and canned it because the factory relays could not handle the load of the fan. I ended up buying a 4th gen rad and using the factory fan setup. I have the setup if anybody is interested for $100
Attached Thumbnails 2004 LS1 GTO harness connector identification-dscf3144.jpg
Old 12-31-2012, 09:45 AM
Lars1's Avatar
Default tcc
Originally Posted by 04GTOintoRX&
I have this details but I need more details.
LS1 2004 Pontiac GTO C-206 Body connector Layout
Pin Wire Color Function
1 (WH) EVAP Canister Vent Solenoid Control
2 (BK) Low Reference
3 (PU/WH) VSS Signal
4 (PU) Fuel Level Sensor Signal
5 (BU/WH) High Speed Cooling Fan Relay Control
6 (OG) Battery Positive Voltage
7 (BN/BU) Ignition 1 Voltage
8 (0G) Ignition 3 Voltage
9 (BK/WH) Delivered Torque Signal
10 (GN) Content Theft Horn Control
11 (GY) Neutral Safety Switch Signal
12 (D-GN) Fuel Tank Pressure Sensor Signal
13 (PK) Ignition 1 Voltage
14 (GY) 5-Volt Reference
15 (L-GN/BK) A/C Compressor Clutch Relay Control
16 (PU) Brake Signal
17 (OG/WH) Requested Torque Signal
18 (RD) Ignition 1 Voltage
19 (BN/WH) MIL Control
20 (RD/BK) UART Serial Data Primary
21 (RD/YE) Battery Positive Voltage
22 (L-GN) Backup Lamps Supply Voltage
23 (GN/WH) Fuel Pump Relay Control
24
25 (BN) Engine Speed Signal
26 (YE) RFA Class 2 Serial Data
Is #16 going to the tcc?
What is #17 ?
Old 09-23-2013, 01:21 PM
TipsyMcStagger's Avatar
Can anyone direct me to a similar depiction/identification of the 2006 LS2 GTO harness connections?
Thanks.
Tipsy
Originally Posted by 91 240
1. PCM blue
2. coolant level sensor
3. ASM (accelerator and servo control module)
4. PCM green
5. PIM (powertrain interface module)...
Old 01-29-2014, 08:55 PM
mdrn69velle's Avatar
Bringing this one out of the grave.. So will it be ok to not use plug#8 (throttle relaxer) and #11. It has voltage for injectors so thats what concerns me.
Old 09-06-2022, 02:44 PM
nicksGTO's Avatar
Default GTO wiring diagram
Do you still have that 2004. GTO wiring diagram lol
I have the entire wiring diagram for a 2004 Pontiac GTO let me know if anyone need a copy it is almost 7MB so I could not upload. Also has any one figured out the C206 connector I am having one hell of a time. I have description but having a hard time figuring it out. e-mail me badmas_manche@yahoo.com if you need a copy.
Old 09-06-2022, 06:09 PM
vdiaz133's Avatar
Smile
I have a copy that I found online. I'll try to figure out how to post it.
Old 09-10-2022, 09:58 PM
vdiaz133's Avatar
Hope this helps
File Type: pdf
Old 09-15-2022, 01:13 PM
1964SS's Avatar
2004 GTO pcm pinouts
https://lt1swap.com/2004gto_pcm_pinouts.htm
Quick Reply: 2004 LS1 GTO harness connector identification
