Project 5.3 in Jeep JK
Old 09-17-2009, 11:57 PM
jkwalkercchs's Avatar
if u need some diagrams for either one pm me i have access to all kind of diagrams
if it is cann buss like bo said u might as well gut the whole harness and build yourself a new one
Old 09-18-2009, 01:58 AM
sleepy_boy1's Avatar
novak has shipped my stuff, ill be recieving it next week!!!!, thats great news for me.... cant wait to get the build started, i think i might go the autometer route... i want a stock look though?.....
im using the standard JK transfercase, NP241
jkwalkercchs ,PM sent
Old 09-18-2009, 08:54 AM
dunes dude's Avatar
about the gauge cluster thing we did something that's awesome on a 95 mustang gt 3v swap we were working on at home we used a 2005 gauge cluster on the 95 it looks way better then the stock one, here are some before-after picture's
Stock
2005 mustang gauges
so my advice is ditch those lame wrangler gauges and put something cool and unique
Maybe something like this would look awesome in your wrangler
If your gonna use autometer gauges then those muscle series gauge's look awesome
Old 09-18-2009, 10:25 AM
my first option is definetly a gm guage cluster, but you never know!!, btw amazing work, is that mustang being builf in the UAE?
Old 09-18-2009, 12:46 PM
dunes dude's Avatar
yes it's home made my older Brother , Me and my cousin worked on the car .It's a 1995 mustang v6 automatic now it has a t5 manaual transmission and a 2005 mustang gt engine using the 2005 mustang wiring harness,It wasnt vey hard to finish the car the hardest thing was the fuel pump wiring but we got it figured out.now its gonna get painted and get a single turbo soon.
If your gonna work on the car in your home it would be awesome not many people here work on there cars on there own and your gonna learn alot we learned alot of things while doing the swap on the mustang just remember to get some good quality tools
Old 09-19-2009, 03:15 AM
should i get a guage cluster from vehicle model and year? or can i get a guage cluster from later model? my wiring harness is from a 2004 subarban...
Old 09-19-2009, 10:54 AM
dunes dude's Avatar
get anything from 03 to 06 from any gm suv/truck or i think even an 07 silverado/sierra classic will fit im not very sure though
Old 09-20-2009, 12:52 PM
we are on holidays here, everything is closed..... i will be going shopping soon to the scrapyards....
Old 09-22-2009, 02:09 PM
ok guys i have run into my first problem, i have decided to go DBW and since im not sure what truck my engine came from i have no idea what TAC and pedel to use, i went to the scrap yard today, and the pedals are different from truck to truck..... i dont even know what the TAC looks like, i need get get this sorted, my conversion parts will be here next week...
Old 09-22-2009, 05:00 PM
Bo185's Avatar
You will need the TAC box, pedal and extension harness. The TAC box is mounted on the firewall.
TAC module has two connections, one for the pedal harness..other hooks into main engine harness this is all you need it should have the 9-pin connector the later ones are 6-pin.
TAC modules have to match up to the year range of the PCM AND the throttle body.
03-05 TAC module works with 03-05 truck TB and 03-05 PCM (BLUE/GREEN connectors)
01-02 TAC module works with 01-02 truck TB, 97-04 Vette TB, and 01-02 PCM (BLUE/RED connectors).
03-05 TAC modules have an aluminum mounting base, 01-02 TAC modules are all black plastic including the mounting base.
So you will need the 03-06 one as well as it's pedal.
Old 09-22-2009, 11:28 PM
ok so i need to get a TAC module with an aluminum base, along with its pedal and the wire that connecter the pedal to the tac and im good to go right? anyone have a picture of the tac? do you know if i need the 6 pin or 9 pin? how do i find out?its a 2004 l59 ...... and will a tac and pedal of another 2004 truck work?
Old 09-23-2009, 09:02 AM
  #32
Bo185's Avatar
Any 2003-2005 GM truck with a LSx should work. The pedal and TAC module. Sorry you need the 9pin one IIR. The 05or06 up are the nine pin ones but they still have the aluminum base so watch out check the pin numbers.
And any 9pin pedal (Vette.GTO. etc) should work it the truck pedal doesn't fit!
Old 09-23-2009, 01:15 PM
  #33
i went to the scrappy today, i got both types6 wire and 9 wire for a steal!!! one came like the picture above but i think the one i need to use looks different.... it has a metal pedal, ... ill take pics of it tomorrow and post them up.....
Old 10-18-2009, 01:02 PM
  #34
ive bee busy, engine and tranny are sitting in place... i had a slight problem with the power steering pump pulley touching the steering box on the jeep, so swaped pulley for a smaller one, will see if it fits tommorow... i hope it does.. im going to start with the wiring tommorow...
will take new pics tommorow
Old 03-20-2010, 09:00 AM
  #35
Ford_Assassin's Avatar
What transfer case are you planning on using?
Thanks!!
  #36
Thanks!!
Old 07-25-2011, 02:01 PM
  #37
gbostic's Avatar
Default Is it Finished??
So what is going on with this project? Is it done? what kinds of issues did you run into? Pics? I am looking at swapping an LS into my Jeep Jk 4 door 2008.
Old 07-25-2011, 05:40 PM
  #38
tribaltalon's Avatar
Thread is over 3 years old. Lol.. Look on jkowners a couple ppl have done the swap. You cannot use the jeep trans or tcase. If I were going to do it, I'd do a 5.3 with a 4L80e and an Atlas. Then you'd still need to upgrade the axles to 60s to handle the power (if you're actually gonna wheel it). I think the better solution is to stay mopar as you can keep the tranny. That's why the hemi swap is so popular even tho it doesn't make as much power as an lsx swap.
Old 12-29-2017, 06:52 PM
  #39
ALAN MCKOY's Avatar
I have an 08 rubicon I was wanting to use an LS1/4l60 I'm wanting to keep all the creature comforts that I can I have read that there are several different wiring harnesses available. From what I have read that painless is one of the less desired ones. I'm hoping yours goes well and I can learn from you how to splice the two harnesses together. Looking forward to updates.
Old 12-29-2017, 08:45 PM
  #40
Received 3,022 Likes on 2,353 Posts
The thread you are replying to is over 6 yrs old. You MIGHT get a reply...
Quick Reply: Project 5.3 in Jeep JK
