chevelle install ?
Old 10-12-2009, 04:58 PM
prot68's Avatar
Default chevelle install ?
Please chime in those with experience installing an LS/tko combo into an A body(68 chevelle). Can the engine trans be installed together or must the trans be installed independently. Can at least the bell be installed on the motor? Im using the typical autokraft pan and edl mounts but was hoping to do as much preassembly as possible. Thanks
Old 10-12-2009, 05:42 PM
robbied31's Avatar
I've installed an LQ4 with a 4l80 and CTS-v pan as one unit in my '67 chevelle. I can't imagine you having any trouble with LS/tko in a '68.
Rob
Old 10-12-2009, 10:39 PM
bczee's Avatar
You should be able to install it either way.. eng/tran combo (it can be a tight fit) or engine 1st with bell housing and then bolt in the trans.
IMO ...it will cut time if you drop them in together..! but mock up the adapter / engine mount 1st without the trans...
Old 10-12-2009, 11:25 PM
pist0lpete's Avatar
On my 67 there was really not enough room to install them together. However a 68 should have slightly more room. I would still recommend doing them as one.
Old 10-13-2009, 04:27 PM
prot68's Avatar
thanks for the input, gettin' close!
Old 10-13-2009, 05:42 PM
Project GatTagO's Avatar
Received 1,417 Likes on 893 Posts
With the Autokraft pan it can all go in together.
Andrew
Old 10-13-2009, 11:21 PM
markarleta1's Avatar
on my 64 malibu i jacked the car (nose) up as high as my stands could go and i tiltd the engine and tranny as much as i could and sliped my 5.3/4l65e in and i used the milodon pan witch is pretty wide, so you shouldnt have a problem. good luck
Old 10-14-2009, 11:44 AM
Les_SS's Avatar
might wanna check this
http://www.pro-touring.com/forum/showthread.php?t=49601
Quick Reply: chevelle install ?
