decided on the CTS oil pan
well, after thinking it over for a lil while, i went ahead and decided to buy the CTS oil pan for my LS Chevelle swap. The LS1 is going in a 69 Chevelle, and the F body pan that i originally tried wasnt working out for me. I ordered the CTS pan, and received it today. Hopefully it fits!!!
Its freezing ***** cold in my shop right now, so i haven't test fitted anything yet, but when i do I will let you all know how it works out!
It should give you more room between the pan and crossmember, but still can be a pita to get the engine in but once it does get pass the front crossmember, you should be good. It also is the reason why I went with it 4 years ago...
Post some picture once you get it positioned ..
what is the different bet. the CTS and truck pan. can someone post up some pics pls. am dropping the motor and tranny in tonight with the truck pan. I know the truck pan hang low , but is the CTS hang low too ?
