Looking for '98 LS1 ECU Pinout
PCM Connector C1 (Red)
Connector Part Information
80 Pin Connector
Pin
Wire Color
Circuit No.
Function
1-2
Not Used
3
WHT
1310
EVAP Canister Vent Solenoid Valve Control
4
BRN/WHT
633
Camshaft Position Sensor Signal
5-6
Not Used
7
YEL
400
VSS Signal High
8
Not Used
9
PNK/BLK
1746
Injector #3 Control
10
Not Used
11
DK BLU
229
VTD Fuel Enable
12
LT BLU/BLK
844
Injector #4 Control
13
RED/WHT
2122
Injector #2 Control
14
DK GRN
59
A/C Status
15
BLK/WHT
845
Injector #5 Control
16-17
Not Used
18
YEL/BLK
846
Injector #6 Control
19-20
Not Used
21
PPL
719
IAT Sensor Ground
22
DK BLU
1225
Transmission Range Signal B
23
LT GRN/BLK
1745
Injector #2 Control
24
BLK/WHT
1704
Sensor Ground Jumper
25
PNK
1224
Transmission Range Signal A
26
Not Used
27
RED/BLK
877
Injector #7 Control
28-29
Not Used
30
GRY/BLK
1687
Spark Retard Signal
31
DK BLU/WHT
878
Injector #8 Control
32
ORN/BLK
434
PNP Switch Signal
33
BLK
1744
Injector #1 Control
34
GRY or WHT
587 or 687
Skip Shift Solenoid (M/T) or 3-2 Shift Solenoid (A/T)
35
LT GRN
1222
1-2 Shift Solenoid
36
DK/BLU
1936
Fuel Gauge Output Control
37
BRN/WHT
419
MIL Control
38
Not Used
39
DK GRN/WHT
459
A/C Clutch Relay Control
40
WHT or YEL/BLK
375 or 1223
Skip Shift Lamp Control (M/T) or 2-3 Shift Solenoid (A/T)
41
BRN/WHT
1173
Low Oil Level Indicator Lamp Control
42
LT GRN
1652
Reverse Inhibit Solenoid Control
43
DK/GRN
335
Cooling Fan Relay #1 Control
44
YEL
573
Crankshaft Position Sensor Signal Input
45
DK GRN/WHT
428
EVAP Canister Purge Valve Control
46
Not Used
47
DK GRN/WHT
762
A/C Request Signal
48
YEL
492
MAF Signal
49
PPL
2121
Ignition #1 Control
50-51
Not Used
52
PPL/WHT
2128
Ignition #8 Control
53
RED
2127
Ignition #7 Control
54
LT BLU/WHT
2126
Ignition #6 Control
55
DK GRN/WHT
817
VSS Output Signal
56
DK GRN
2125
Ignition #5 Control
57
DK GRN/WHT
2124
Ignition #4 Control
58
LT BLU
2123
Ignition #3 Control
59
BRN/WHT
2130
Ignition Control Reference Low Bank 2
60
BRN
2129
Ignition Control Reference Low Bank 1
61
RED
1226
Transmission Range Signal C
62
BLK
552
EGR Pintle Position Ground
63
BLK
407
A/C Refrigerant Pressure Sensor Ground
64-70
Not Used
71
PPL
401
VSS Signal Low
72
BLK
451
PCM Ground
73-74
Not Used
75
GRY
720
Left and Right Fuel Tank Level Sensor Ground
76
BLK
451
PCM Ground
77
PPL
420
TCC/Brake Switch Signal
78-80
Not Used
PCM Connector C2 (Blue)
80 Pin Connector
Pin
Wire Color
Circuit No.
Function
1
TAN
1671
HO2S Signal Low Bank 2 Sensor 2
2
TAN/WHT
1669
HO2S Signal Low Bank 1 Sensor 2
3
TAN
800
Serial Data (UART)
4
RED
631
Camshaft Position Sensor B+ Supply
5
TAN
1667
HO2S Signal Low Bank 2 Sensor 1
6
TAN/WHT
1653
HO2S Signal Low Bank 1 Sensor 1
7
RED/BLK
380
A/C Refrigerant Pressure Sensor Signal
8
TAN
472
IAT Sensor Signal
9
BRN
1456
EGR Pintle Position Sensor Signal
10
PPL
30
Fuel Level Sensor Signal
11
Not Used
12
DK BLU
417
TP Sensor Signal
13
YEL/BLK
1227
Transmission Fluid Temperature Sensor Signal
14
ORN/BLK
1057
Transmission Fluid Temperature Sensor Ground
15-18
Not Used
19
PNK
439
PCM Ignition 1 Feed
20
ORN
340
PCM Battery Feed
21
BLK
451
PCM Ground
22
YEL/BLK
1868
Crankshaft Position Sensor Ground
23
BLK
452
TP Sensor Ground
24
BLK/WHT
1704
25
BRN
718
ECT Sensor Ground
26
ORN/BLK
469
MAP Sensor Ground
27
Not Used
28
DK BLU
473
Engine Cooling Fan Relay #2 and #3 Control
29
Not Used
30
BRN
436
AIR Pump Relay Control
31
PPL
421
AIR Solenoid Relay Control
32
TAN/BLK
422
TCC Enable Solenoid
33
BRN
418
TCC (PWM) Solenoid Valve Control
34
GRY
435
EGR Valve Ground
35
WHT
121
Engine Speed (Tach) Output Signal
36
LT BLU/WHT
1229
Transmission Fluid Pressure Control Solenoid Control Low
37
DK GRN/WHT
465
Fuel Pump Relay Control
38
LT BLU
697
EGR Valve Control Circuit
39
RED/BLK
1228
Transmission Fluid Pressure Control Solenoid Control High
40
Not Used
41
PPL
1670
HO2S Signal High Bank 2 Sensor 2
42
PPL/WHT
1668
HO2S Signal High Bank 1 Sensor 2
43
GRY
596
TP Sensor 5V Reference
44-45
Not Used
46
PPL
1666
HO2S Signal High Bank 2 Sensor 1
47
PPL/WHT
1665
HO2S Signal High Bank 1 Sensor 1
48
LT GRN
432
MAP Sensor Signal
49
YEL
410
ECT Sensor Signal
50-51
Not Used
52
DK GRN
890
Fuel Tank Pressure Sensor Signal
53
Not Used
54
LT GRN/BLK
444
IAC Coil B Low
55
LT BLU/BLK
1748
IAC Coil A Low
56
LT BLU/WHT
1747
IAC Coil A High
57
LT GRN/WHT
1749
IAC Coil B High
58
PPL
1807
Serial Data (Class 2)
59
Not Used
60
BLK
451
PCM Ground
61
ORN
340
PCM Battery Feed
62
LT GRN
1867
Crankshaft Position Sensor B+ Supply
63
Not Used
64
GRY
416
MAP Sensor 5.0 Volt Reference
65
GRY
705
5V Reference
66
GRY
474
A/C Refrigerant Pressure Sensor 5.0 Volt Reference
67
GRY
598
5V Reference
68
LT BLU
1876
Knock Sensor (KS) Rear
69
DK BLU
496
Knock Sensor (KS) Front
70
PNK/BLK
632
Camshaft Position Sensor Ground
71-75
Not Used
76
BRN
1174
Oil Level Sensor Signal
77-80
Not Used
80 Pin Connector
Pin
Wire Color
Circuit No.
Function
1-2
Not Used
3
WHT
1310
4
BRN/WHT
633
5-6
Not Used
7
YEL
400
VSS Signal High
8
Not Used
9
PNK/BLK
1746
Injector #3 Control
10
Not Used
11
DK BLU
229
VTD Fuel Enable
12
LT BLU/BLK
844
Injector #4 Control
13
RED/WHT
2122
Injector #2 Control
14
DK GRN
59
A/C Status
15
BLK/WHT
845
Injector #5 Control
16-17
Not Used
18
YEL/BLK
846
Injector #6 Control
19-20
Not Used
21
PPL
719
IAT Sensor Ground
22
DK BLU
1225
23
LT GRN/BLK
1745
Injector #2 Control
24
BLK/WHT
1704
25
PNK
1224
26
Not Used
27
RED/BLK
877
Injector #7 Control
28-29
Not Used
30
GRY/BLK
1687
Spark Retard Signal
31
DK BLU/WHT
878
Injector #8 Control
32
ORN/BLK
434
PNP Switch Signal
33
BLK
1744
Injector #1 Control
34
GRY or WHT
587 or 687
35
LT GRN
1222
1-2 Shift Solenoid
36
DK/BLU
1936
37
BRN/WHT
419
MIL Control
38
Not Used
39
DK GRN/WHT
459
40
WHT or YEL/BLK
375 or 1223
41
BRN/WHT
1173
42
LT GRN
1652
43
DK/GRN
335
44
YEL
573
45
DK GRN/WHT
428
46
Not Used
47
DK GRN/WHT
762
A/C Request Signal
48
YEL
492
MAF Signal
49
PPL
2121
Ignition #1 Control
50-51
Not Used
52
PPL/WHT
2128
Ignition #8 Control
53
RED
2127
Ignition #7 Control
54
LT BLU/WHT
2126
Ignition #6 Control
55
DK GRN/WHT
817
VSS Output Signal
56
DK GRN
2125
Ignition #5 Control
57
DK GRN/WHT
2124
Ignition #4 Control
58
LT BLU
2123
Ignition #3 Control
59
BRN/WHT
2130
60
BRN
2129
61
RED
1226
62
BLK
552
63
BLK
407
64-70
Not Used
71
PPL
401
VSS Signal Low
72
BLK
451
PCM Ground
73-74
Not Used
75
GRY
720
76
BLK
451
PCM Ground
77
PPL
420
78-80
Not Used
80 Pin Connector
Pin
Wire Color
Circuit No.
Function
1
TAN
1671
2
TAN/WHT
1669
3
TAN
800
Serial Data (UART)
4
RED
631
5
TAN
1667
6
TAN/WHT
1653
7
RED/BLK
380
8
TAN
472
IAT Sensor Signal
9
BRN
1456
10
PPL
30
11
Not Used
12
DK BLU
417
TP Sensor Signal
13
YEL/BLK
1227
14
ORN/BLK
1057
15-18
Not Used
19
PNK
439
PCM Ignition 1 Feed
20
ORN
340
PCM Battery Feed
21
BLK
451
PCM Ground
22
YEL/BLK
1868
23
BLK
452
TP Sensor Ground
24
BLK/WHT
1704
25
BRN
718
ECT Sensor Ground
26
ORN/BLK
469
MAP Sensor Ground
27
Not Used
28
DK BLU
473
29
Not Used
30
BRN
436
31
PPL
421
32
TAN/BLK
422
TCC Enable Solenoid
33
BRN
418
34
GRY
435
EGR Valve Ground
35
WHT
121
36
LT BLU/WHT
1229
37
DK GRN/WHT
465
38
LT BLU
697
39
RED/BLK
1228
40
Not Used
41
PPL
1670
42
PPL/WHT
1668
43
GRY
596
44-45
Not Used
46
PPL
1666
47
PPL/WHT
1665
48
LT GRN
432
MAP Sensor Signal
49
YEL
410
ECT Sensor Signal
50-51
Not Used
52
DK GRN
890
53
Not Used
54
LT GRN/BLK
444
IAC Coil B Low
55
LT BLU/BLK
1748
IAC Coil A Low
56
LT BLU/WHT
1747
IAC Coil A High
57
LT GRN/WHT
1749
IAC Coil B High
58
PPL
1807
59
Not Used
60
BLK
451
PCM Ground
61
ORN
340
PCM Battery Feed
62
LT GRN
1867
63
Not Used
64
GRY
416
65
GRY
705
5V Reference
66
GRY
474
67
GRY
598
5V Reference
68
LT BLU
1876
69
DK BLU
496
70
PNK/BLK
632
71-75
Not Used
76
BRN
1174
77-80
Not Used
