Trouble Re-Starting Motor - After it hits operating temperature
1998 LS1 in conversion vehicle:
So first thing in the morning when everything is nice and cool my motor starts right up real fast; perfectly, with no issues.
Say I go for a 15 minute ride allowing the motor to reach normal temperature operating range, like stopping at a gas station or whatever, I go to start it right back up, the starter cranks perfectly (starters not getting hot) and it doesnt want to fire, it just cranks and cranks...
I end up having to wait about 20 minutes for the engine to cool down and then it starts up again just fine.
Any ideas what may be causing this? My only guess right now is that my fuel lines are getting too warm, also my throttle body cooler line is not hooked up, not sure if that has anything to do with it.
I am kinda stumped here and looking for some ideas, thanks in advance.
Sounds like the ECT/spark table settings are pulling start up spark. Do you have tuning software? I have assumed that the car is PCM controlled & not a carb. For example: when cool, ECT/spark may send 24* & once warm is may be pulling -20*. This is just an example of what the ECT/spark table can do, not an exact as to what it is doing. My first guess is the ECT switch/sensor.
What year PCM & did you do anything non-stock w/ the coolant temperature switch/sensor? If the stock sensor has been used & is connected properly, then send "Frost" a PM. Discuss the problem w/ him. He is a professional tuner & can fix it through the mail, ie; you send the PCM, then he makes the changes & returns it.
I have a 2000 z28 tune in my pcm. I am pretty sure I do not have a temp sensor though. Still waiting for my gages to arrive.
Right now I have a plug in the passengers side head, and Im not even sure whats in the drivers side, havent looked yet.
This is probably whats causing my problem is no temp sensor going to the pcm...
Not probably, since it's not there, the PCM is going into panic mode. It thinks it's -30*F upon start up & then goes into temp protection mode after running for a while. The PCM MUST have ECT (engine cooling temp) feedback. Get a 2000 ECT switch, mount it to the head & connect it to the harness. This will fix the problem. BTW, you're dumping gobs of fuel into the cylinders @ start-up. Once you add the ECT switch, change the oil it has fuel in it.
Going to get the ECT & new oil on my lunch break.
Im a newb learning something new everyday. Greatly appreciate your help!!
so i installed the temp sensor and plugged it into the harness it ran good for like 5 minutes and then the engine started running like total garbage. it was so disappointing. its like the engine hit a certain temp and the pcm adjusted the air fuel ratio to the point it would barely run. it left me stranded on the road i ended up unpluugging the temp sensor just so i could drive home. looking for some more help here its greatly appreciated
I'd say that it's related to your ECT spark table settings, since after you installed the temp sensor, trouble remains. However, what sensor did you buy & what color are the wires that connect to it & how many wires? Any chance that you can see what numbers on the PCM that the wires connect to? Maybe it's the wrong sensor. It's a 2000 PCM on a 98 LS1. The 2000 PCM uses a 2 wire & the 98 is a 3 wire ECT sensor. You need the 2000 sensor.
If you're gonna get into tuning it, buy either EFILive or HP Tuners. I use EFILive. For just logging, then something other than these 2 can be used.
Yes trouble remains, but its a different kind of trouble. Before the temp sensor it just wouldnt start after it got hot. Now, it straight up just runs so bad it stalls when it hits operating temp.
The sensor I bought was for a 2000 z28. Same year pcm and same tune, they are both two wire (harness and sensor).
guess its going to take data logging to fix this, unless I just some how get lucky with the disconnect the battery thing..
