no spark
Old 06-20-2010, 10:30 AM
superpaul72's Avatar
Default no spark
72 nova ls1 swap factory ecm speartech harness no spark ?
Old 06-20-2010, 01:49 PM
crainholio's Avatar
Verify 12VDC at the coil pack harness connectors on each bank.
Assuming Speartech uses stock power distribution, you can easily check this by testing any injector connector for 12VDC when probing to ground w/ the key in the RUN position. You should find 12VDC on one of the two pins, with your meter's negative probe grounded.
Old 06-21-2010, 05:22 AM
LS1MCSS's Avatar
We need more information. Do you have power when the key is on but not when you start cranking? What kind of car is the motor in?
