5.3 in 70 gto
Old 07-11-2010, 03:47 PM
gtonut1970's Avatar
Default 5.3 in 70 gto
i have a 5.3 out of a 02 suburban that i want to put into my 70 gto, i want to put an ls1 intake on it, and i know that the accessory drive will have to be changed, but im not sure what to use, i want to run p/s and a/c, any help would be greatly appreciated. and im on a limited budget so no high doller billit kits for me. thanks
Old 07-11-2010, 06:31 PM
bagged67camaro's Avatar
All i did on mine was chop off the alt mount part on the ps/aly mount and relocate the alt to the pass side worked pretty good u still gonna use the drive by wire setup?
http://sphotos.ak.fbcdn.net/hphotos-..._6486159_n.jpg
Old 07-11-2010, 07:13 PM
gtonut1970's Avatar
its cable drive, what did you use to relocate the alt? i like that set up you have. ive read that the stock a/c location will hit the frame on the a body, any ideas? whats yours going in? r you gonna run a/c?
Old 07-11-2010, 07:57 PM
71 chevelle's Avatar
go to the sticky's its been covered many times. You can use the truck drive just need to move a idler. Info on how to is also on the sticky's.
Old 07-11-2010, 09:07 PM
I just pulled off the stock idler and the bottom bolt on the alt will go into 1 of the old idler holes and made a adjustable bracket for the top. Mines goin in a camaro with vintage air u cant use the newer ac compressors (something with variable output????) so i bought a sanden off a 90 corrado and gonna move it closer to the block with a custom mount.
Old 07-11-2010, 09:51 PM
gtonut1970's Avatar
thanks for the info, im sure ill have many questions for this build. love that chevelle!!
Quick Reply: 5.3 in 70 gto
