72 Chevelle Conv. SS LS6/ Tremec 5-speed
Old 07-22-2010, 07:06 PM
MeanYellowZ's Avatar
Default 72 Chevelle Conv. SS LS6/ Tremec 5-speed
Just wrapping up a 72 Chevelle SS. This car came to me as a big block (402)/ 4-speed with the following complaints, poor fuel mileage, not enough power, horrible exhaust drone, and no air conditioning. We pulled it all apart, ended up upgrading all the suspension and brakes, installing a Tremec 5 speed behind a new crate LS6 engine. Along the way the car was filled with sound deadening, new stereo, full exhaust, new axles, brake lines, air conditioning added and many other things. The car purrs like a kitten now, with 405 horsepower on tap. It runs at 180 degrees while idling for LONG periods of time with the air conditioning on full blast keeping the inside super cool. It's a great all around driver now! Enjoy:
Here is what I started with....a relatively freshly restored 72 Chevelle SS convertible. Big-block/ 4 speed are gone....parts are stacking up
fresh GM LS6 crate engine
New Tremec TKO600 5-speed transmission.
Started tearing out all the suspension getting ready for all new BMR tubular/ boxed upper and lower control arms for front and rear, Bilstein shocks all around, lowering coil springs and bigger sway bars with all new poly bushings.
Threw new wilwood disc brakes all the way around too while we were in there..
Tore the interior out to rewire everything/ install sound deadening everywhere/ added Vintage Air A/C kit and a full Alpine stereo.
Got the mockup engine in and setup all the brackets and A/C stuff and tested fit many other components at that time.
Then it was time for the real engine:
and finished.....
Old 07-22-2010, 07:51 PM
john 67's Avatar
REALLY nice and neat job , got me thinkin' bout doin my 70. did you have any issues with the vintage air? ( my belt seems to be slipping around the compressor sometimes ). JOHN
Old 07-22-2010, 08:33 PM
chevellepowered's Avatar
super clean..nice work...
Old 07-22-2010, 09:45 PM
pmgm's Avatar
Thats a good looking car!!
Old 07-22-2010, 10:18 PM
LS1 SPEED's Avatar
Randy
car looks good and now only needs an induction and dyno tune to wrap it up
Old 07-23-2010, 10:07 AM
wish I had more time with this one, I would love to see what power could be pulled out of the stock Z06 engine.
Old 07-23-2010, 01:04 PM
Pop N Wood's Avatar
Out of curiosity why did you select an LS6 motor instead of an LS2?
Although now that I look it seems like both LS2 and LS6 crate motors are getting hard to find new. Maybe you already had one?
Old 07-23-2010, 03:40 PM
patriotformula's Avatar
Turned out great!
Old 07-23-2010, 04:28 PM
bczee's Avatar
Great job and the transformation is right on !
Which mounting plates did you use.. ?
Suggestion, get your body guy to do something about the coil cover.. (remove the Corvette and add Chevelle or ???)
Old 07-23-2010, 05:55 PM
71 chevelle's Avatar
Yep Felser is making some billet inserts that say Chevelle.
Old 07-23-2010, 06:05 PM
Gray86hatch's Avatar
Looks good
What did you do with the clutch linkage, What motor mounts, Trans tunnel mods to get the drive line angels correct?
I am collecting parts to do a swap on dads 71 this winter
Tim
Old 07-24-2010, 06:48 PM
SlvrSierra4.8's Avatar
Originally Posted by Gray86hatch
Looks good
Tim
Interested as well.....
Old 07-24-2010, 11:37 PM
sixgunsblazing's Avatar
Very nice project!
how fast was the turnaround from the car arriving to being finished?
Old 07-25-2010, 12:51 PM
We used the CarshopINC 1" setback plate which is the same dimensions as the Edelbrock plates. Tunnel mods were relatively minimal (hammer) since its a sure-fit (ha) TKO kit with case modifications. Clutch hydraulics are the kit from American Powertrain using a Wilwood master. Turnaround time on this project was 10 weeks.
Old 07-25-2010, 02:46 PM
gofastwclass's Avatar
Another fine Yates creation!
Nicely done! Keep up the good work bro!
Old 07-25-2010, 05:02 PM
Thank you sir....this one is a damn fun car to cruise around.... doesn't have any issues...truly drives like a new car.
Quick Reply: 72 Chevelle Conv. SS LS6/ Tremec 5-speed
