PS Pump Install & Removal w/ or w/o pulley?
Does the PS pump pulley need to be removed to install and remove the pump from a truck LSX? My pump came with the pulley detached and I'm not sure if I should wait until AFTER the pump is mounted to attach it or if I can attach it now and leave it on. I'm not sure if I'll be able to reach the mounting bolts with it installed.
Thanks for any tips.
I have had to do it both ways, depending on the engine/mount/pump.
You can try and get a very slim wrench to loosen that bolt behind the pump. Many have said to use one of them Bicycle pedal wrenches.
I just picked up a check Harbor Freight puller/installer kit.. or was that from Kragen.. anyway.. it can be done (some times ??? LOL).
