LY6/4L80e from rough van into rough 69 camaro
Old 08-21-2014, 03:51 AM
  #821
tsnow678's Avatar
Dan you might want to consider notching the frame on the new car to allow clearance for the alternator and a/c compressor to be mounted low rather than up top. Any videos of the booger running with the new setup? Any passes achieved yet?
Old 08-21-2014, 11:37 PM
  #822
bmf5150's Avatar
I think that's a great idea for the AC
Old 09-02-2014, 08:49 PM
  #823
futureuser's Avatar
I agree. The compressor and alternator are a little close to the headers.
A friend and me are tuning ourselves. No full throttle runs yet, but it is running well and comes on boost nicely at part throttle.
Greddy Profec Controller and wideband AFR. Maybe I should have got the gauges in blue, lol.
Mostly buttoned up.
Old 09-06-2014, 10:17 PM
  #824
futureuser's Avatar
Default 7.5psi unlocked converter
Lots of fun on the street, lol. The rpm band is off because the converter is unlocked in 3rd gear. There was no need to go beyond 6000 rpm.
Old 09-07-2014, 10:53 AM
  #825
tsnow678's Avatar
What psi are you eventually hoping to shove into the LY6? Love that whistle!!!
Old 09-07-2014, 12:39 PM
  #826
futureuser's Avatar
Not sure. I really don't feel like building a motor right now. I'm going to drive it like this and then I might turn it up to 9 pounds. It should last a long time like this.
I designed the turbo system to upgradable. With a larger compressor wheel, a forged motor, and another fuel system upgrade, 1000whp is doable.
Really it is so much fun right now, I need to leave it like it is and finish the new shell this winter. Problem is turning up the boost is as easy as turning the **** on the boost controller. The Greddy Profec works well with the 50mm wastegate.
Old 09-08-2014, 01:22 PM
  #827
-TheBandit-'s Avatar
Holy **** dude!
Old 10-22-2014, 07:43 PM
  #828
futureuser's Avatar
http://i1136.photobucket.com/albums/...pslacb0wea.jpg
Old 10-22-2014, 07:48 PM
  #829
futureuser's Avatar
Old 10-22-2014, 07:53 PM
  #830
futureuser's Avatar
I've had a little fun. I'm blowing smoke out of the breather and valve cover. Did I hurt a ring?
Old 10-23-2014, 02:51 AM
  #831
Jimbo1367's Avatar
Dude, I hope not. Looks bad azz 4 sure.
Old 10-23-2014, 10:58 AM
  #832
Originally Posted by futureuser
I am doing most of the welding on the new shell now. But meanwhile, the green car is being fitted with something new thanks to my friend Matt Smith who runs Exotic Exhaust. Does anyone recognize the white car parked next to mine? He has been tasked with fitting 2 sets of headers and exhaust systems to it.
I just noticed that car has two LSxs in series. Wow! Am I seeing that right? More info needed.
Love the looks of your turbo setup. You've really gone full-tilt with this car. Awesome!
Old 11-02-2014, 06:23 PM
  #833
futureuser's Avatar
Thanks. Yes those are twin LS7s. It uses a corvette 4L60, diff and surprisingly doesn't use up too much interior room. That car will probably end up in some magazines soon, when it is complete, unlike mne, lol.
http://www.americanv8.com/
My trash will be getting rods, pistons, studs and hopefully a new body soon.
Old 11-15-2014, 11:55 PM
  #834
futureuser's Avatar
Old 11-16-2014, 11:32 PM
  #835
Frawgdawg26's Avatar
It has taken me two nights to read this entire thread and I must say you are doing a most awesome build! Salute to you sir!
Old 11-18-2014, 03:23 AM
  #836
Jimbo1367's Avatar
Frawgdawg26,
And Futureuser did a lot of this in his driveway in the WINTER. He's truly CRAZY!!!!!
Old 11-18-2014, 11:52 PM
  #837
futureuser's Avatar
Thanks! While it is true that I did the full conversion and subframe rebuild outdoors, in the winter, I have since moved and now am lucky enough to have a garage. I am going into high gear with the new body shell, and the engine rebuild. I have read numerous articles on what stock engines can take with boost. Unfortunately, on that second run, a good friend of mine posted for me, my opponent hit the wall, and i hurt the motor. There is no knocking, just some blow by. My motor came out of an almost brand new van, but had water in it, from the intake. So who knows if there was rust in the rings, which may have weakened them.
I data logged these last two runs with HP Tuners. 17 dgrees timing, no knock, 7 psi, and iats peaked at 150 degrees. 112-114mph 1/8 mile. Time to forge the motor and turn up the boost I posted a dyno graph, but do the math with 3800lb race weight and I think the junk yard motor with water in it did okay. I could probably but a new piston in it with a new ring and keep going, but I really want to turn it up. (A little)
Old 11-19-2014, 07:03 PM
  #838
Jimbo1367's Avatar
Sounds like a plan. Congrats on the new house and garage !!!
Old 11-25-2014, 06:42 PM
  #839
tsnow678's Avatar
408? or are you going over the top? RHS block?
Old 11-27-2014, 12:54 PM
  #840
futureuser's Avatar
Thanks Jim, and No Sir Tony! Pistons, rods, studs and stock stroke. I'm even planning to leave my cam alone. The money will go into upgrading my turbo compressor, torque converter, nine inch and chassis.
Quick Reply: LY6/4L80e from rough van into rough 69 camaro
