A/c and radio do not work after swap 95 v6 to 00 ls1
I have a 95 fbody origv6 camaro that I did a complete 2000 update on. My donor car was a 2000 t/a ls1 auto. I used the entire chassis and engine Harness from the t/a in the camaro. The only part I did not use from the t/a was the steering column. I used the 95 column. I have not started chasing the problem yet because I wanted to ask here first. Every thing else works in the car accept for the radio and the a/c (blower motor) the radio is a monsoon unit so I don't know If the column is an issue or not since I don't have radio controles on the wheel.
Has anyone else had this problem?
Fuses
I would start to check fuses and your original wiring, the problems you are having usually are not related to the swap you did, you may have blown a fuse during the wiring phase of the swap or damaged some other wiring in the process of the swap, your problems are kinda like my sister's car, if I work on her transmission she call a week later and say a tire is flat and it must have something to do with the transmission work I did, your problem sounds a little incidental.
Lol ar the flat related to the tranny work. I kind of thought it night be a bad ground or something I just haven't had time to chase it down. Thanks for the input and keep the ideas coming.
