ls1 powered ford five hundred?
Old 11-19-2010, 08:14 PM
nunan0219's Avatar
Default ls1 powered ford five hundred?
i've been searching but havent found anything, but has anyone done an ls1 ford five hundred? i'm stuck with mine (not worth as much as we owe) so if i'm going to keep it, i might as well enjoy it. anyone seen one?
Old 11-19-2010, 10:24 PM
Irish350's Avatar
i havent seen an ls in any newish (like that) fords, except the lincoln ls and mustangs. That said, if the electronics arent too crazy it wouldnt be bad, pending all the normal stuff like mounts,headers, etc.
Old 11-20-2010, 10:18 AM
philntx's Avatar
Might be a little more complicated because it's FWD or AWD only.
Old 11-20-2010, 03:26 PM
EnfuegoZ28's Avatar
If it's FWD you should be able to adapt the Impala SS/GP GXP stuff to work on it. It would be a good starting point.
Old 11-20-2010, 07:22 PM
slow's Avatar
the electrical portion of the swap will be a nightmare to keep the ford SJB and original IC using the lsx control system.
Ryan
