Mustang hydraulic clutch conversion
Old 03-12-2011, 09:10 AM
zipster's Avatar
Default Mustang hydraulic clutch conversion
got my clutch set up done. Just throwing this out there to let others get a visual on another way to do it.
I used a 3/4 bore Wilwood master, a 1/4 aluminum plate and put it next to the booster. There was a hole there already, I just had to make it bigger.
Then I welded a 1 inch square tube to the pedal, with a bolt that was welded on the back side of the plate on the end.
I used a small rod end with left hand threads that were the same size as the rod coming out of the master and drilled and tapped a piece of square stock and welded a piece of left hand threaded rod to the end of the square stock, this made a small adjustable turnbuckle.
total $ under $60.00
Old 03-12-2011, 08:30 PM
ponjohn's Avatar
Interesting...very clever.
Is the throw on that m/c 1"?
Old 03-13-2011, 09:22 AM
72Elkytpi's Avatar
Do you get alot of travel when depressing the clutch pedal. I tried to do mine lower on the pedal for a bigger arc swing. your set up is alot cleaner than mine, I like it alot.
Rich
Old 03-13-2011, 10:36 AM
zipster's Avatar
Thanks guys.
I measured the swing, its 1 1/16, I can adjust it by 1/8 either way. the way it sits, it has a little less than the stock Mustang throw. I will paint it before final assembly.
Old 03-13-2011, 12:26 PM
themachasy's Avatar
very nice!!
Old 03-13-2011, 12:38 PM
ponjohn's Avatar
A few more questions...how is the pedal height compared to brake pedal?
Are you planning on putting a stop in so it doesn't injure the m/c?
Old 03-13-2011, 12:53 PM
zipster's Avatar
The pedal height is the very close to when it was original. its about 1/2 inch lower. Right now I have 1 1/16 stroke, the master has a total of 1.40.
http://www.wilwood.com/Images/Master...304_dwg-lg.jpg
It should be good. Just measured the pedal height, its 2 inches above the brake pedal.
Old 03-14-2011, 08:51 AM
johnyrrr's Avatar
Link no work for me, why would pedal hieght be different, isnt this the stock clutch pedal or is this a Turbo Coupe pedal. Ive said before, Zipster you got skills....., wanna come help with my setup
Old 03-15-2011, 06:16 PM
ponjohn's Avatar
My thought was IF he moved the pedal in / out to adjust for the throw it may be lower or simply uncomfortable.
Old 03-15-2011, 06:32 PM
zipster's Avatar
The pedals I used were stock 5.0 Mustang clutch/brake pedals. I was able to lower the pedal just a touch because I am 6'4" and these fox Mustangs are a little tight for taller people. The link was just a diagram of Wilwoods specs on the clutch master I used. It stated 1.40 inches of travel is maximum for this master.
Johnnyrrr
Thanks for the comment!
Old 03-16-2011, 07:46 AM
johnyrrr's Avatar
You make it look so easy Zipster. Maybe I will try your clutch actuating method as opposed to the Turbo Coupe pedal method. I did find a Turbo coupe pedal setup but could always sell it off if I dont use it
Johnnyrrr
Old 03-16-2011, 07:57 AM
johnyrrr's Avatar
Zipster do you have any pics of the hard line go from the master cylinder to the tranny and how it hooks up to the T56? Can I assume you used part number 260-1304 from Wilwwod, did you oreder direct from them?
Old 03-16-2011, 05:00 PM
zipster's Avatar
I dont have it connected to the trans just yet, I have to bend the hard line down around the steering column boot. then I have a fitting that goes from the brake line to -4 there is a rubber coated hanger that holds it to the body. Then a small SS flex line to the slave cylinder. Yes the master is the Wilwood 260-1304. I got it from ebay was around $40.00 shipped
you can see the line goes under the booster. now just to put it in a good place.
Old 03-17-2011, 04:23 AM
boosted4.6's Avatar
very very nice job man!
Old 03-17-2011, 09:14 AM
jonathan_ed3's Avatar
Very clever!
Where did you get the maximum stroke info? I have been trying to find it for Wilwood #260-3378
Old 03-18-2011, 06:25 AM
zipster's Avatar
Originally Posted by jonathan_ed3
Very clever!
Thanks!
The info came from the instructions and their web site, I just checked Wilwoods site about your master, nothing listed. You might need to call their tech line.
Old 07-06-2011, 09:56 PM
vnmous97's Avatar
looks great i wish i could use this for my 97 Cobra but i dont think it will work
im in the process of using ls1 trans am 2002 pedal assembly and mcloed adjustable master cylinder (freebie ) it was already on the car at my salvage yard.. i just might try and see if i cant fab the fox pedals in
Old 07-06-2011, 09:59 PM
vnmous97's Avatar
i dont know if there is room
Old 07-06-2011, 10:05 PM
zipster's Avatar
I used a 1995 brake booster, I had to drill out one of the holes because it also bolts in the pedals. I would bet the fox pedals would/can work.
Oh, wait. doesn't the 97 Cobra have hydraboost? I would have to see the way it bolts into the car. It might work.
Old 07-07-2011, 07:46 AM
vnmous97's Avatar
yes hyrdraboost.. which i want to keep.. the booster location is the same on
****by the way the new 05-2011 mustang use hydraulic clutch and the master cylinder mounts under the dash on the pedal assembly
Quick Reply: Mustang hydraulic clutch conversion
