ls2 into a 2002 assesories drive help
I'm currently swapping a 2004 6.0 with an ls2 intake into my 2002 s10 2 wheel drive and i'm having problems figuring out my drive brackets. I tried truck brackets and they wont clear the throttle body and the f body alternator bracket is too low. So will the f- body powersteering bracket and pump work with with a top mount alt bracket? I also notched the frame for ac clearence and the truck pump doesn't clear, does the f body? Thanks in advance!
Truck intake with truck accessories is the easy way to go, you should have enough height, I did in my s10 (1st gen). Otherwise take a look at the ctsv setup GMPP has, you could probably use some of that.
i mocked up a f body water pump and power steering pump and they look great now i need to find out if i need the alt. and ps in one mount or the passenger side alt mount. Any one done either of these?
Try Current Performance. They seem to do a bunch of these swaps. www.currentperformance.com
Have you tried the Corvette accessories? The PS pump is located like the F-body with the alt mounted above it.
Good luck!
Dhamen
Good luck!
Dhamen
