What to do with the 3rd power steering line outlet on the pump?
Old 05-06-2011, 12:16 PM
70cartruck's Avatar
Thumbs down What to do with the 3rd power steering line outlet on the pump?
Since i have had my car going the powersteering setup has never been quite right. The pump had been ran dry several times before and finally last week it quit working. The question i have is this, i only have 1 pressure line and 1 return line for my powersteering box.....what is the proper thing to do to get rid or block off the third return line on a lq4 power steering pump. I did have a piece of rubber line with a bolt in the end to block it off.
I know there is a proper way to do this i just cant remember how
thanks
Old 05-06-2011, 01:11 PM
71ANTICARB's Avatar
If your setup isn't leaking then there is nothing wrong with how you have it. You you want it to look a little cleaner the the parts store have rubber caps you can use.
Old 05-06-2011, 03:56 PM
70cartruck's Avatar
it just seems like it could be done a better way......the rubber hose has a bolt with a hose clamp on it and i can see fluid bubbling around the bolt....i just thought there was a better way....
Old 05-06-2011, 04:12 PM
71ANTICARB's Avatar
Well the "best" way would prolly find a pump w/o the hydroboost return.
Old 05-06-2011, 04:19 PM
72chevelle6.0's Avatar
yea get the 5.3 pump with out hydro boost..
Old 05-06-2011, 06:24 PM
zipster's Avatar
I welded mine shut.
Old 05-08-2011, 02:36 PM
theomms's Avatar
Maybe you could add hydroboost to your car?
Quick Reply: What to do with the 3rd power steering line outlet on the pump?
