72 Camaro LS6/T56 Swap Help
Old 07-14-2011, 10:11 PM
71chevykid's Avatar
Default 72 Camaro LS6/T56 Swap Help
I've been a big fan of muscle cars for years...finally can't deal with carbs anymore. Looking for some help getting started with my swap of a ctsv ls6/t56 into my 72 camaro. if anyone has done this and cares to help with pics advice and other info i'd appreciate it.
Attached Thumbnails 72 Camaro LS6/T56 Swap Help-camaro.jpg   72 Camaro LS6/T56 Swap Help-camaro-1.jpg   72 Camaro LS6/T56 Swap Help-camaro-2.jpg
Old 07-15-2011, 12:14 AM
mice13's Avatar
Main reason i did my swap was to get rid of the old carb...so what is it you needed help with
Old 07-16-2011, 08:57 AM
71chevykid's Avatar
When you did your swap did you use the factory harness or did you purchase a painless harness to make life easy. I've been told I should purchase a new gas tank with a fuel pump mounted in the tank, but if I can avaiod an $800 gas tank that would be nice too. Did you have to do any accessory relocation? Any pictures? What are some of the things I should look out for?
Old 07-16-2011, 10:47 AM
Rick Speed's Avatar
That is an Awsome car. I'm doing a 79 TA. All the wiring was cut up so I'm wiring a 2002 Harness with all the 2002 body/engine bay harness's.
Old 07-16-2011, 12:20 PM
71chevykid's Avatar
Post some pics of the 79. I called down to Street & Performance and they were helpful. After speaking to them they made it seem extremely easy. In fact those were his words when I told him the swap details. They did an 80 firebaird and posted pics and discussion.
http://www.hotrodlane.cc/PDFFILES/80%20firebird.pdf
apparently they do a boat load of swaps and installs. I plan on doing a throttle by cable over wire install. I hate electronics and those hideous pedals
Old 07-16-2011, 02:24 PM
mice13's Avatar
When i bought my engine i was able to get the complete harness with it. I found wiring diagrams/Pinouts online and converted the harness myself to save $$. For the gas tank i left my stock tank and just put an inline fuel pump with the corvette filter/regulator, works fine! And for acc i used the stock ones. Engine was out of a 98 T/A. Look out for crap motor mount adapter plates!!! I got the carshop 1" setback plates and used clamshell mounts and motor just sit right in.
Old 07-26-2011, 04:28 PM
71chevykid's Avatar
I've ordered my gas tank from rock valley. I've also decided to do a complete suspension upgrade on the camaro. Should be fun.
- Heidts IRS
- Heidts ProG subframe
Quick Reply: 72 Camaro LS6/T56 Swap Help
