LS1 swap charging issues
I was just fighting a dead alternator - exciter wire was ~1 volt less than battery voltage.
You can test the alternator by hard wiring the exciter wire to 12volt - you aren't going to hurt anything running it for a few minutes that way. You can also wire it to a battery light in the car if you wanted to do it that way.
sweet ! thanx for the info....After further evaluation, it seems I have everything wired correctly and all the wiring is good. I wired up an idiot light under the hood to simulate a dash light and the alternator wont charge that way either. I have a good alternator coming from a fellow Tech member, hopefully my troubles will be over soon. Thanx everybody
It would have, kinda. I was removing the alternator in preparation for the new one when it got here and noticed there was no nut on the battery charging wire stud. Apparently some dumbass had forgotten to put it on and the wire was just bouncing around on the stud causing my issues. So there you go, no matter how good you remember installing parts always double check everything when troubleshooting a problem. I knew that but thought I had everyhting covered. Thanx to everyone who helped me out.
