LSX in a '68 Javelin
Hello all,
New here but not to automotive forums. There is a wealth of knowledge here with tons to absorb. I have a '68 Javelin with a mild 343 with a TKO 600 modified by modular mustang racing to handle anything I could possibly throw at it. It is all well but the money it would take to take that 343 or any AMC engine for that matter into the 11's reliably is just unreasonable to me. I am also not thrilled with the TKO trans but that is a story for another day.
I have some questions that I hope you guys can answer. I have a crossmember that I purchased to swap a standard 350 sbc into a Javelin. What would be needed to make an LS work in that spot? I am assuming from what I have read just a set of sliding engine mounts from one of the parts house.
I am thinking of a 5.3 mated to a T56 as a start. I cant break the bank on this swap and I dont care if the engine bay is "pretty" so other than that I see no need to swap in the LS1 for the extra cost. I already have a hydraulic clutch set-up for the TKO so I am thinking little is needed to make the T56 work behind the 5.3.
I am looking to pick up a 5.3, its harness, computer and probably the pedal for the drive by wire system. Is there anything I am missing?
I have a fuel system that would need tweaking. I have an RCI fuel cell with 1/2" line to the front of the car. I know I would need a return and upgraded pump but I feel like something else is missing. Any suggestions on this end of things?
I have a nice 4 core radiator with 2 spal electric fans that kept the 343 right around 170 degrees. I think i am set with the cooling side of things.
As far as the stock harness goes from what I have read I basically just cut everything peripheral off and just retain the bare necessities to make the engine run. I am sure I could find a tuner here on Long Island to flash the ECM to my needs(any suggestions here would be nice as well).
Suggestions, comments, answers and questions are all welcome,
Thanks in advance,
Larry
Thanks in advance,
Larry
The ones that are around are usually die hard stocker type guys. Picked up the crossmember for free from someone who took the small block out of their Javelin. I am going to document things as much as I can. The car really doesnt have too much stock at this point. Just front suspension at this point really. I am hoping there will be some guys on here with some good feedback to get me started and in the right direction.
I put a 99 LS1 and 6 speed in my 66 Rambler American. Fit snug but really well. Had to shorten the steering column tube for clearance. Made my own motor mounts on the stock six banger crossmember. Had to notch the rear of the crossmember a little to clear the oil pan. Moved the stock trans crossmember to the rear to make it work. I'll try to post some pics. Let me know if you have any specific questions.
1968 javelin LS swap steering
I have a 68 javelin, swapped the straight 6 for ls1, using a mustang II front suspension and shortie headers with a t56 transmission. Running into issues with a steering column fitting any recommendations on which to buy would be helpful. Feel free to email ewhited1@gmail.com
Be a little more specific about "issues with a steering column fitting"
Steering column
Any suggestions on a steering column for a 68 javelin. I have an LS1 with a t56 that I swapped but the column is hitting the engine mount. Also running into issues with a pedal assembly the ones used in an LS1 are too short, any suggestions?
Any way to put U-joints in the steering shaft?
Ethan,
I sent you an email a few weeks ago. Here is what my steering set-up looks like. See this thread for more pics: https://ls1tech.com/forums/conversio...ommencing.html
Larry
Larry
The following users liked this post:
G Atsma (01-22-2020)
