e38 standalone, starts and dies after 2 seconds max
Hello everyone
Im using wiring and all stuff from a 2007 silverado.
I disabled VATS, used a 100 ohm resistor on he black and yellow wire. the car was running, then took it to a 3 min ride.... after that the car only starts and dies and throws code crankshaft relearn, do you have any ideas?
thanks
thanks
Hmm this does sound like a vats issue, did you go through the crankshaft relearn procedure and it is still doing this?
Its not crank learn, that wont work in a conversion. If you can scan the injectors and coils that will tell you whether it is a VATS or ECM start related issue or something like a bad MAF or wiring.
