Fitting for power brakes part number 12559760
Old 08-09-2011, 09:25 AM
Thealien's Avatar
Default Fitting for power brakes part number 12559760
I remember seeing the question asked a few times and while going through some old pictures I found a picture and part number for the fitting that goes into the truck manifold for vacuum for power brakes when the intake originally had a plug for hydroboost brakes. Maybe somone can put this somewhere it will be easy to find??
Attached Thumbnails Fitting for power brakes part number 12559760-part-12559760.jpg
Old 08-09-2011, 09:36 AM
ls1nova71's Avatar
That's some good info. Now if someone could find the part number for the hydroboost plug.....
Old 08-09-2011, 10:46 AM
Thealien's Avatar
Are you talking the part that fits in that same hole to plug it?
If I was in a bind I would just use a small hose off the fitting I listed and a bolt or ? to plug it. I am kind of **** myself and would want the correct plug. Must be easy to find at a junk yard? I may have mine somewhere but I plan to someday go to hydroboost and will want that same plug?
Old 08-11-2011, 04:26 AM
ls1nova71's Avatar
Yes, that's the plug I was talking about. I finally did find one, but when I went to the dealer, they couldn't find it or a part number for it. All the.exploded views show is the nipple for power brakes.
Old 06-12-2012, 01:11 PM
Squeezer's Avatar
THANK YOU for sharing this information, this is the part I'm looking for right now.
Glenn
Quick Reply: Fitting for power brakes part number 12559760
