Dirty Dingo motor mounts for A body swap, thoughts? Also have accsry question
Has anyone used these for a 68-71 Abody swap? If so, would you recomend them?
http://dirtydingo.com/store/American...bflrfivf4clib4
Also, I have an LQ4 shortblock with L92 heads with truck crank pulley and water pump, that's it. No idler, no alt bracket etc. I've also got a carb intake so tb clearance isn't an issue. I'm not running a/c or a power steering pump, should I just run the smokinhawk alt. setup??? I've read the alt. hits frame with the F-body setup. Suggestions welcome!!
I used them in my F-Body 2nd gen and was very pleased with the fit and the quality.
https://ls1tech.com/forums/chevrolet...77-camaro.html
My son has the BRP mounts on his '79 Camino. They fit well. With the urethane bushings on the BRP mounts, he feels he is getting more vibration from the motor than he expected. One of the reasons I chose the Dirty Dingo adapters was that I could use the factory motor mounts with the rubber bushings.
