??? for L92 owners.
if i can get the oil pressure gauge working, my gauges would be fully functional(tach, speedo, v-meter, coolant temp, fuel)
if thats not the route i need to take, i'm open to suggestions.
On a typical oil pressure gauge there will be three wires. dumThese wires are for switched ignition power, oil pressure signal, and ground. dumIn order to take advantage of the oil pressure gauge driver follow the gauge manufacturer’s wiring instructions.
The connector has 3 pins.
A, B, and C.
A=?
B=?
C=?
Switched power, ground, pressure signal
Can someone put these by there correct letter?
Ex..5V switched should read ?ohms
Volts for the 5v "key on" check. Black lead to ground, probe the 3 wires with the red lead. Whichever wire shows 5v is the power wire.
The remaining wire is the signal wire.
